Is $6700 a reasonable estimate on replacing the entire unit, in and out? 3.5 ton
  • t1m130
    t1m130 May 11, 2010
    what brand is it and what is the seer rating is it 410a or R-22 it never hurts to get more than one estimate dont tell them what the other guyis going to charge you
  • 52 Answers
What seer range and brand.also where are you located it makes big difference.
Posted on Aug 25, 2009
I have a Carrier Weathermaker model #38tdb060300 A/C system. How many tons is that? It is 11 yrs old, capacitor exploded and compressor is blown. Needing to replace.
Looks like a 5 ton unit. However, you might be better off finding a R-22 condensing unit to replace the entire outside unit. Reason being, if you just replace the compressor, you get a one year warranty. If you replace the whole outside unit, you get a 5 year warranty. You can replace the outside unit with any manufacturer, as long as it is the same tonnage and type (heat pump/air conditioner/single stage/ 2 stage ...).
Oct 13, 2014 | Heating & Cooling
Should I replace the fan or the entire unit?
i would try fan. 18 seer unit should last awhile longer.
Jul 30, 2014 | Kenmore Icp Comfortmaker C4a836gkd 3 Ton...
Replacement for 20yr old A/C system
I you have a 2.5 ton condenser on a 3 ton coil, and he gave you an estimate for a 1.5 ton condenser only, he missed something, or you need a second estimate. Now if give you an estimate for a complete system, with a 1.5 ton condenser/evap, coil, your ductwork will/may be oversized for that unit. Need a second estimate. You've been happy with a 2.5 ton cooling capacity in the past, don't settle for anything less, unless you've completely updated with new doors, windows, insulation, ect.... I'd call around and ask for an estimate, with a load, and then ask for the cooling tonnage and furnace BTU's from that load, when they call with the price. Most reputable companies will/can prove a proper load calculation and my city just made it mandatory to prove a load was achieved when a permit is pulled due to the Dept. Of Energy passing laws on this subject in 2015. Ask if its mandatory for a load calc. if they pull a permit. And they are supposed to pull a permit in city limits I'm sure. It's not a good practice to miss match systems with current designs. 20+ years ago it was, but now there are codes against this practice. And also shortcuts to try to make more money with less invested may not be considered GOOD PRACTICE. Hope this helps!
Mar 13, 2017 | Heating & Cooling
I would like to get a unlock code for nokia 6700 classic and its on network 3
It's locked to Australia's Network 3 or United Kingdom 3 Network,I have Unlocked my Same Phone Nokia 6700 Classic from Australia 3 Network using the Unlock code ,i got the Unlock code from here Theunlockarena.com and Unlocked it...
Aug 11, 2011 | Nokia 6700 Classic Cell Phone
Recently replaced entire central a/c - Removed 2,500 ton Rheem condenser - Unit is approx. 2-1/2 to 3 year old - 13 Seer - Interested in selling unit...Who made be interested in purchasing??? What would...
Hi, 2,500 ton unit would be the size of a 15,000sq.foot warehouse! I think you mean a 2 1/2 ton Rheem condenser. You could run an add under Craigs list.com, and if the unit is in good shape, I would ask no more then $600 for it. As a Contractor, I can get them anytime new for around $660.00. If you can get $500 for it jump on it. Best of luck to you,
Shastalaker7
A/C Contractor
Jul 26, 2011 | Heating & Cooling
I am removing a 3 ton condenser and replacing with a 31/2 ton condenser . The evap coil is a 3 ton with an expansion valve with a 11/2 ton to a 3 ton rating. Will i have any problems. The 31/2 ton unit is...
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Jun 21, 2011 | Heating & Cooling
Have a WeahterKing WBEA 14J055FCIA Inside split air system. Last tenant removed the outside compressor. Looks to be a 2.5 ton unit and need to find an replacement outside compressor that will match up. Is...
James if you are able, go on to craigslist and try to find you a used outdoor unit. I have several rentals and craigslist has saved me several times. I bought the last unit , 3 ton, used for $100.00.
Apr 20, 2011 | Heating & Cooling
Need help on tonnage question
I would have an air conditioning contractor do a heat load calculation and give you and estimate. 3 ton may work if your insulation is good and your windows seal well. 4 ton may be too much and you won't get the humidity removal needed in Florida.
Mar 04, 2010 | Heating & Cooling
Inside coil ices over
You have 3 ton unit. Reasons for icing are stopped up filter.dirty indoor coil and low on refigerant. The first two you can do but the last you need a service tech but ask for free estimate first. RUSS
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
