Question about Apple MacBook Air
When i shutdown my macbook air, it starts up automatically and wont shutdown until i pressed power button, what shall i do to shutdown without pressing power button? Pls HELP!!!
  • 1 more comment
  • chopan Jul 29, 2009
    i have 10.5.7. When I shut it down, it shuts down but starts up automatically after a few seconds. It only shutdown fully (don't restart)when I press power button for a few seconds.
    thanks.
  • chopan Jul 30, 2009
    can quit all programs and shut down completely when I press power button for a few seconds. But when I want to shutdown per shutdown procedures, it shutdown but restart automatically after 2 - 3 seconds even when lid is closed.
    thanks.
  • Kenneth Klare
    Kenneth Klare May 11, 2010
    What version of OSX are you running? Per chance 10.5.7? Do you mean shutdown or just closing the lid? Check that System Preferences :: Energy Saver does not have "Restart automatically on Power Failure" checked. The alternative would seem to be to sleep before closing the lid--Apple Menu :: Sleep or Power button, then "S" to sleep. Power + return does a shutdown. BTW, do you have some other wake option turned on?
    -Ken
  • 221 Answers
there should be a program that does not quit. Can you tell what software is the last to quit before this occurs?
Posted on Jul 29, 2009
Why wont my computer turn on macbook air. what do you think?
could be a number of things including the power block faulty, a break in the power lead, the power regulator in the macbook or even it's just plain old dead. if the macbook lights come on when it's plugged in and nothing else happens when you press the power button, odds on it's just dead.
Jan 30, 2015 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My mcbookair wont shutdown
long press the power button for 15 seconds
Mar 30, 2011 | Apple MacBook Air
My laptop has suddenly frozen, i turned it off by the power button and whenever i try to turn it on it turns white screen, then shutsoff after 3-5minutes.
Resolution
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter, learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
Also:
The MacBook SMC Firmware Update v1.1 improves the MacBook's internal monitoring system and addresses issues with unexpected shutdowns. This update is recommended for all MacBook systems, including those that received warranty repair.
You can use the Software Update feature of System Preferences, or download the MacBook SMC Firmware Update v1.1 from Apple Software Downloads.
Note: If your MacBook is running Mac OS X 10.4.6, you won't be able to see the SMC Update until you update to Mac OS X 10.4.8. Once you have updated your system software, the SMC Update will appear as an option in Software Updates.
MacBooks running Mac OS X 10.4.7 will be able to download and install the SMC Update, so it is not essential that you update your system software, although Apple always recommends updating to the latest version of the system software.
If your MacBook is in a state where it will not remain on long enough to install the update, wait for the issue to reproduce itself. Once the MacBook has turned itself off, turn the computer on by holding the power button down. Keep the button down until you hear a single long tone. Once you hear the tone you can release the button, install the recommended updates, and restart normally.
Dec 30, 2010 | Apple MacBook Mac Notebook
How do you reboot a apple laptop, my laptop is messed up!?
When you mentioned in the issue detail, that your Macbook portable "is messed up", without more details, I honestly cannot tell to what extent you are having issues with your Macbook.
So to better assist you, I am going to provide a few troubleshooting steps to see if this can help with your Macbook's rebooting up to the desktop normally.
Procedure #1
Here are some steps you can try to resolve the issue:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
This should help with the freezing issue:
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the startup sound for the third time.
• Release the keys and allow the Macbook to start up.
If the PRAM reset still does not help, try this second procedure below.
Procedure #2
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Give this a try and you should be able to boot up normally. If not, let me know.
Thanks!
Regards,
-Mactechtrainer
Jan 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book chimes on start up but no screen comes on
Make sure the MagSafe adapter is securely attached to the Macbook and free of debris.
There are two procedures that are advised by Apple to assist in resolving issues where the Macbook chimes at start up, but displays no video.
Here is the first procedure:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
Observe to see if your Macbook will boot to the Desk top normally. If it does not, here is the second procedure:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac computer.
• If the computer is on, turn it off.
• Disconnect the AC adapter and remove the computer's battery.
and then release the button.
• Reconnect the battery and AC Adapter.
• Press the power button to restart the computer
Update me if you require further assistance.
Regards,
-Mactechtrainer
I can't get the mb397g/a working on my apple HELP Pz
Try this procedure with the Macbook Air SuperDrive
and then click the Apple link below to follow the remaining recommended steps with for troubleshooting your Macbook Air SuperDrive.
• Make sure your SuperDrive is connected to your portable.
• Properly shut down your Macbook Air
• Once it is is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
Apple Support Link:
Troubleshooting the MacBook Air SuperDrive
This process is supported by Apple, but if it does not work, just let me know.
Regards,
-Terry
Oct 30, 2009 | Apple MB397G/A MacBook Air SuperDrive
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Press and hold the power button. After a few seconds, the MAcBook will shut down.
Regards,
Cybernanga
A Frozen 2008 Macbook Air
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
Mar 08, 2009 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
Apple MacBook Air Logo
321 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
