Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is saying F dL when I try to start a load
Can you manage to lock +unlock door buy shutting off machine and starting over .does it run for a while then shut down / if you shut of machine will door unlock .if so ccu board could be problem
Posted on Jul 29, 2009
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Receive a DL error when trying to start my front load washer (the door will not lock)
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
At the end of the cycle when the machine goes to spin the machine stops saying DL. I looked it up in my manuel and that means door won't lock. But it was locked the whole cycle until the end. I emptied...
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Aug 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer reads dL f and door stays locked even
try to start another cycle then hit cancel and cancel again and it usually unlocks the washer
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer code says dl? and wont start
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, if required, and the steps required to replace any defective parts.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
DL f flashing and beeps
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
