Brother CS-80 Logo
Anonymous Posted on Nov 09, 2017
Brother CS-80 Sewing Machine Bobbin Rewind
My Brother CS-80 Sewing machine has a problem with the bobbin rewind. The motor hums but does not turn the bobbin. I was told that the o-ring might be bad and I could go in and replace it by removing one screw and the cover would open up but that didn't work for me. Can some one help me? Thank you very much.
Ruth
R.A. Ellis
Level 3:
  • Brother Master 12,731 Answers
  • Posted on Nov 09, 2017
R.A. Ellis
Brother Master
Level 3:
Answers
12731
Questions
Helped
2613527
Points
59176
For $30 you can buy a standalone bobbin winder (Sidewinder) at JoAnn's Fabrics or Amazon. It's a great little accessory (battery or electrical) because it saves wear and tear on your machine but also allows you to wind multiple bobbins without having to unthread the machine.
5 Related Answers
Anonymous
  • Posted on Oct 14, 2008
SOURCE: Sewing Machine CS-8060
I do have the very same problem! I took my bobbin case out and took a good look at it, turns out right below the plastic hook part, the plastic was cracked off (probably due to thread jamming). Turns out I need a new internal bobbin case, which range in price from $35-$50 from what I researched. I had no luck with local sewing centers on finding the part.
That may (or not) be your issue as well. Good luck, and I hope this your issue is simple fix. A little tune up after might be needed, HAPPY SEWING!! ~Kelly J~
flyred77
  • Posted on Nov 10, 2008
SOURCE: Can't wind the bobbin
Hi again,
Well we finally downloaded a service manual that cost a few bucks, then finished getting the machine apart, then found a small rubber O-ring that had obviously gotten hot when spinning after the tangling of the thread on the bobbin stem. You could see where the heat had melted tiny teeth marks in the ring and it was stretched out of shape. It and yours too will need to be replaced.
If you or someone you know is mechanically inclined, you will need to take five screws out of the back including a hard to find one under the foot raising lever (lower the foot), then one form the front that is under the thread cartridge, and you will have to remove the bobbin winding plate cover which is held by one small screw, and then remove a small screw from the support bar.
Beverly McDonald
  • Posted on Apr 05, 2009
SOURCE: I need to rewind a new bobbin
My SE-270D bobbin winder is located on the top of the machine to the far right. From the picture of your machine it looks to be in the same place. The larger spindle is for the spool of thread and the shorter spindle is for the bobbin.
You need to wnd the thread around the bobbin a few times just to make sure it is started properly, and then move the bobbin either forward or backward to engage. (It's different on some machines.) You may also have to move the outer edge of the machine wheel (the large wheel on the outside right) to keep the needle from moving up and down while the bobbin is filling. When the bobbin is full the machine should shut off by itself.
Then you will have to re-tighten the machine wheel to engage the needle.
Hope this helps.
Anonymous
  • 52 Answers
  • Posted on Jul 16, 2009
SOURCE: Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Anonymous
  • Posted on Jul 28, 2009
SOURCE: viking sewing machine 545 bobbin stuck on rewind
Most machines you slide the bobbin winder to the right to wind and then back to the left when your done to remove. Just making sure.... you did move it back to the left?
Can`t rewind bobbin
Sounds like it may be a bad solenoid or clutch inside. When it tries to reverse direction to rewind is sounds like it's getting stuck. The lights comming on might be an indication that the machine detects a problem. You could try to open it and see if any of the gears are broken or out of place or if any of the teeth on the gears are missing. But I would get it serviced if you're not comfortable with opening it up.
1helpful
2answers
Unlock brothers LS2125i sewing machine
Is the thread caught in gear in top of machine causing it to bind. If you refilled bobbin did the gear switch back completely or you have lost an o ring in bobbin rewind.
How to trouble shoot without a manual?
you can download a free manual at //www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm
F4 might mean that the bobbin on the top is in the position for rewind, slide bobbin to the right for the error code to go away. Hope this helps, Sandy
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
1helpful
Bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
2answers
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
