Question about Dometic Rooftop RV Air Conditioner
Tripping of AC after running good for hours.
Hi,I have a 1.5 tonn Carrier AC which worked fine for summers last year. This year around 10 days back I ahd the socket and 3 pin burnt due to unknown reasons and now we got a new 3 pin of ANCHOR(considered to be best here) and now the AC trips after say about 2-3 hours of running.At times, we have lots of light fluctuation and the back up starts working and AC starts working.I am not sure why the socket and 3 pin burnt at first, why would that be?Also now this tripping of MCB for only the AC point on daily basis with uncertainity of what time it would trip.Is the AC not functioning, or it is the stabliser that has gone crazy or still it is only due to the fluctuations?I have same power Carrier AC in the other room, but that never created any issue so far.Please help.Also please let me know, if pulling up the tripped level and using the Ac damages the AC by nay means?Also we use this AC for complete night without any break while the AC for the other room is switched off for some breaks, does this also affect?Thanks.
  • sehgalnidhi1 Aug 04, 2009
    Hiifixalot4her, Thanks for your reply. We have a 7.5 KVA(not sure what are these units) electricity and backup from generator is 2.5 KVA.
    I got my AC serviced at the beginning of this summer before using the AC, I think there some wire must have been connected incorrectly. Also we have 3 phases and on the phase of my AC we just have an LCD TV. So I probably think it has to do something that happened during the service.
    I will call My AC service man again to get more acuret diagnosis of the problem.
    But I want to add that twice we had the #pin and the Socket burnt up and then we changed it and yesterday itself we had the switch(on/off) linked to 3 pin melt up. I got it changed again. But can you tell me what all can lead to burning of 3pin, socket and the on/off button for AC and the tripping for AC point?
    Can this affect the AC directly or it would only affect the stabliser? The Stabliser makes more sound nowadays when the compressor starts. Is the AC getting into problem?
    Should I stop using the AC till the correct cause is known?
    What all wrong can happen during a WET Service of the AC that causes it to trip or get burnt down?
    Should I give the AC some breaks during night and will that help?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
CARRIER REQIRES AT LEAST 10 VOLTS OF DC POWER TO RUN THEMOSTAT FUNCTONS YOU ARE HAVEING A PROBLEM WITH YOUR CONVERTER OR INVERTER IF YOU HAVE A MOTOR HOME NOT PRODUCING ENOUGH DC VOLTS TO POWER THEMOSTAT FUNCTION I NOTICED YOU SAID YOU HAVE TWO ACS ON THE COATCH IF YOU HAVE A 3 PIN SOCKET YOU ONLY HAVE 30 AMP SERVICE KEEPING IN MIND YOUR AC REGUIRES 16 AMPS TO START AND 11 TO RUNS SO THAT WOULD BE
AC X 2 22 AMPS RUNING
WATER HEATER AC POWER 7 TO 8AMPS
REFER 10 AMPS ON ELETRIC MAX
CONVERTER DEPENDS ON BATEERY USE BUT I WOULD SAY 6 AMPS NORMAL USE WITH A GOOD DEEP CYCLE INSTALLED ON COATCH
I SEE OVER 40 AMPS WITH OUT ANY TVS OR MICO OR THE ALL IMPORTANT WIFES HAIR DRIER
Posted on Aug 01, 2009
  • ifixalot4her Aug 01, 2009
    THIS IS WHY YOUR PLUG MELTED AFTER RE READING YOUR MESSAGE I WOULD ALSO CHECK YOUR BREAKER BOX AND BREAKERS FOR LOOSE CONNECTIONS AT THE BREAKER WITH THE POWER UN PLUGGED OF COARSE ALSO MAKE SURE THE CORRCT WIRE NUTS WERE USED UPON INSTALLATION OF THE AC SHOUD BE THE YELLOW ONES THEY ALSO LIKE TO COME LOOSE SO RETIGHTEN THEM AND TAPE THEM SO THEY DO NOT BACK OFF
I have an Intex 18x48 easy set pool and pump is shutting off/tripping circuit breaker after running for 1 minute for last 2-3 days. I called Intex (after reading questions posted here) and they are...
Pour some bleach (about 2 gallons) around the perimeter and give it a good brushing. May have to repeat in a few days. That should hold fine.
Jun 26, 2013 | Pool & Spa
Samsung 2.0TR split ac compressor getting heated up and tripped after running for 10 mins
High limit switch set to high, obstruction in the system, or your compressor may be wearing out.
Apr 12, 2013 | Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
1994 c280 overheating in summer swelter. Where do i start?
Sounds like the radiator is not moving enough air. Is the fins plugged with dirt or bugs?
Jul 08, 2010 | 1994 Mercedes-Benz C-Class
I just had my 2003 T & C with dual AC controls
hi there:
the easiest way to check for a leak would be to use a black light and follow the a/c lines around looking closely for the glow of the dye also look real close around the fire wall condenser and the evaporator to insure the system is sealed tight also check around the a/c pump pulley for any signs of leaks you can also check the a/c clutch by starting the van and switching a/c on to see if the clutch is engaging.... hope this helps thanks
May 30, 2010 | 2003 Chrysler Town & Country
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
Engine shutting down in extreme heat
Mine does the same thing as far as shutting down on long trips---usually 1 1/2 - 2 hours. I don't think it's overheating....it's got something to do with antitheft system
Aug 09, 2008 | 2002 Chevrolet Suburban 2500
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Dometic Rooftop RV Air Conditioner Logo
297 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
