Question about Cycling
Forgot combination I have a prestolock but I can't remember the combination. It has 4 number rolls. Is there any way to get the combination? There is a pat. number on the back. Carla Halazon 425-483-3604 - home phone
  • 3 Answers
Nope. Cut it off.
Posted on Aug 04, 2009
Lost my combination for prestolock tsa400 hoW do I open it
Go to the companies website at this address they may be able to help you open your lock. http://www.safeskieslocks.com/support.html
Aug 17, 2014 | Home Security
Presto combination lock
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
I've forgot my code for samsanite case and its locked please help
Set the lock on 999, push the buttons on the latches to the outside. If that doesn't work, roll the last number from 9 to 8 and try again. Then roll it to 7 and keep trying, rolling the last number down to 0. Then roll the middle number from 9 to 8, and move the LAST number to 9, and start the whole thing again. When you get to the end of that, roll the middle number on down to 7 and the LAST number on down to 9. Keep doing this until it unlocks (note the numbers at that point to remember!), or, you may have to go on down through the first numbers as well. You only have 1000 possible combinations. That sounds like a lot but if you are watching TV while you are mindlessly rolling a number wheel and then pushing the latches out, it's not too bad, only about an hour ... your thumbs will get sore. :-(
May 31, 2012 | Photography
I changed my phone's security code and I forgot what it is. I've been trying different number combinations but I can't really remember. By the way, here's my IMEI: 355375/00/747102/90521971 Type:RM-30
You can try default code "0000" or "1234" and if it still does not work then try master reset code to reset your nokia 6030..try Unlock-Free to get reset code for your mobile by submitting the imei number of your mobile and get master reset code to reset your mobile..
Dec 26, 2011 | Nokia 6030 Cellular Phone
I need instructions for "can't
"To begin, the deck of cards is spread out. Each card contains a number, from 2 through 12. The player on turn rolls all four six sided dice. From the roll, players may combine two sets of two dice to make a number, placing chips on the matching turtle cards. For example, if a roll of 2, 3, 3 and 4 is rolled, a player may combine the 2 and 3 (to make 5) and the second 3 and 4 (to make 7) and place a chip on the 5 and 7 turtle cards respectively. An even better play would be to combine the 2 and 4 and both 3s to earn TWO chips on card number 6. A player may continue to roll and place chips as long as he is able to combine at least ONE combination that is still viable. When it a number not viable? When the matching number card is won and out of the game!
As a player rolls and chips mount on cards, a player may choose to stop and mark on the score sheet the number of chips he has placed on a particular card or cards. Should a player place the required number of chips on a card (an amount that varies from only two for cards 2 and 12 up to seven for card number 7), that player claims that card and both that card and number are now out of play. Should a player be unable to place a chip on a card on his turn, his turn is over and all chips placed on that turn are lost! The first player to successfully claim three cards wins the game!"
Source
May 18, 2011 | Toys
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
Jun 13, 2009 | Sentry Fireproof Safe
Forgot the code for my sentry 3110 safe
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of safes:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
If you need to retreive your lost combination, you can get it at this link:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jan 09, 2009 | Sentry Fireproof Safe
We just moved and lost combination to our sentry safe
goto SentySafe.com
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
register and request the combination base on the serial number.
they should be able to send you the combination keys
Nov 25, 2008 | Sentry Fireproof Safe
How do I Unlock Ipod screen if I forgot the 4 digit password?
no no no no no no no!!!!!!!!!!!!!!!!!!!!!!
When connect ipod to computer, go to my computer. Click on ipod:-
-click on tools, go to folder options
-go to view tab
-check show hidden files
-a ghost like folder will apear: ipod control
-click on it and go to device
-there will be a locked file
-click and delete it
Your ipod is unlocked!!!!!!!!!!!!
JOHN
If you don't understand, go to this website on you tube!
http://www.youtube.com/watch?v=Au6H_u-q434
Sep 30, 2008 | Apple iPod classic MP3 Player
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
Cycling Logo
408 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
