Question about Sharp XL-MP130 CD Shelf System
Sharp XL-MP130 CD shelf sys. won't all
Whenever I plug in the CD player, it starts clicking and none of the buttons work. i think it might be the fan since the noise is coming from there. i usually leave it unplugged so that it stops making the noise.
Re: sharp XL-MP130 CD shelf sys. won't all
Hi There,
The clicking noise is usually the power supply "tripping" because of an over load, your explanation of the fault is very good and helps us in advising you about the fault...
Because the clicking gets slower it means that you have reduced the current being drawn from the power supply.
The item that is causing the over load is the item that when you plug it in or turn it on causes the clicking to start up...
Tyhe power supply is called a switched mode power supply and is usually a collection of transistiors capacitors resistors and a transformer all specially set up to make DC Direct Current and AC alternating current power for your electronics to work with.
These power supplies are expensive and no fuses are employed to make them work but a special detector circuit is installed to close down the power when a high current draw down is detected, Once the high draw down is detected the power supply closes itself down, so then it sees no more high current draw down so it starts up again and this causes the click as the internal transformer and capacitors once again start the cycle to operate to make the DC/AC supplies. So once started up the High current is detected and the power supply closes it self down and the cycle is repeated over and over....
Its a specialised job to locate the problem so its not something you can do your self without electronics training...
Cheers From YUBEUT
Posted on Nov 24, 2007
0 characters
3 Points
Sharp XLMP 130 power button Blinking Red Light - Nothing Works
??? ?????? ??? ??? ?????? ?? ?? ??? ???? ?????? ?? STK 412-490 ?? ???? ???? ???? ????? ?? ?? ???? ?? ??? ??????????? ? STK ?????? ?????? ??? ??? ??? ?? ????? ??? ??????? ???? ???? STK ????? ???? ??? ??? ??? ?? ???? ?????? ??? ???? ??? ?
Jun 08, 2016 | Sharp XL-MP130 170-Watt 5-Disc CD Micro...
Need a owners manual for my XL-MP130 shelf system
Google it " XL-MP130". you will get several sites of them...for free download.
Jan 10, 2011 | Sharp XL-MP130 CD Shelf System
Hi! I'm a music teacher who just came back from summer vacation and plugged in my xl-mp130. It seems to be in sleep mode or something. There is a little red light that blinks just below the word...
i would do a hard reset to start and that is simply unplugging the unit for approx 5 mins than plugging it back in--a power surge or brownout can confuse the micro and a reset is all it needs sometimes--good luck!
Sep 01, 2010 | Sharp XL-MP130 170-Watt 5-Disc CD Micro...
Unit will not come on, but timer button is blinking
Well, it thinks it's set to come on under Timer control.
Get the manual out (or go to, register and download it for free) and go to page 34 and cancel the timer.
Canceling the timer setting in the timer stand-by mode:
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the or button to select
"ONCE" or "DAILY", and press the MEMORY/SET button.
3 Within 10 seconds, press the or button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY/SET button.
Timer will be canceled (the setting will not be canceled).
Mar 10, 2010 | Sharp XL-MP130 CD Shelf System
The CD player will not play. It worked yesterday
Please open the lnik of your computer and run microsoft fix it.
after that restart the computer, hopefully it will work.
Oct 23, 2009 | Sharp XL-MP130 CD Shelf System
My XL-MP130 stereo makes a racket...
What your machine is doing is... whenever the unit is powered on or off the cd player resets itself and the clanking you hear is the cd changer resetting itself.  The plastic trays of the cd player are driven by plastic gears.  These gears are noisy when new, after a few years, they can make quite a clanking noise.  Most cd changers of this age have similar mechanisms and this type of noise is inherent in their operation.      I'm afraid the only solution is to replace the unit.  Opening the unit to lubricate the gears may cause more problems than it may solve, so I would not recommend it.
Jan 02, 2009 | Sharp XL-MP130 CD Shelf System
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Sharp XL-MP130 CD Shelf System Logo
245 people viewed this question
Top Sharp Audio Shelf Systems Experts
Are you a Sharp Audio Shelf System Expert? Answer questions, earn points and help others
