Question about Saniflo Sanibest macerator with multiple connections
I am missing the small white cap that sits over the air hole ontop of my saniplus system do you know where i could get a replacement cap from. Thank you
  • 117 Answers
Call a local plumbing suppily house, or check on line to see who carrys your system close by. If not let me know
Posted on Jul 28, 2009
2004 Jeep Grand Cherokee 4.0L, oil leak ontop of engine, around and infront of oil fill hole.
Gasket/O-ring bad on the oil fill cap. The fan is throwing it around where you've found the excess.
Nov 12, 2017 | 2004 Jeep Grand Cherokee
Odor when water turned on
Most Saniflo products comes with a 1/2" opening on top of the pump casing, which the opening is for European installations only (this is also used in Europe) in the US the 1/2" opening must be kept plugged, if left open, odor will come out of the hole there. But make sure that you cap the 1/2" opening and vent the unit using the 1 1/2" vent connection on top. Make sure is vented to the open air, as air must flow in and out at all times.
Dec 06, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a twyford toilet with a saniplus system behind. This suite was added when the previous owners had a room and ensuite built over the garage. There is always a disgusting smell coming from the...
Check the top lid of the pump casing. There is a 1/2" hole on top which must be kept plugged or seal capped. If left open odor tends to emmitt from there. Also check for any loose connections or waste leak at the bottom of the pump casing or the bowl.
May 25, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
I own a 1985 300zx Turbo?.I like to know why my
Your overflow tank works on suction to return coolant to the radiator. Check the line and nipple ends for any cracking (cracking on the plastic radiator nippl is very commom). The radiator nipple is not under high prrssure like the fluid under the cap (inside the coolant system). It's on the otherside of the cap and will never "stream or gush" coolant (uless you are over heating badly). As the coolant in the radiator cools it creates a vacuum and draws coolant back from the overflow throgh a small hose. You might not see any leaks as coolant heats up and travels to the overflow. It might be a very small leak and you are usaully driving around and drying up before you see it. Even with a very small crack it will only draw in air and not liquid (as liquid is way heavier than air). Also, I've seen where people have taken out (or fallen out) the tube attached to the overflow cap that goes down deep into the overflow tank. That tube should be long enough to almost reach the bottom of the tank. It's hard to know if something is missing if you do not know it was suppose to be there in th first place but it needs to be there.
Jul 04, 2010 | 1985 Nissan 300ZX
Bad smell fro macerator when toilet flushed after being left overnight
Typically on macerating or grinder pumps there is a small 1/2" breather hole on top of the lid, about the size of a dime or nickel. That breather hole must be kept plugged or seal cap. If left open, odor will escape through there. Make sure the pump is vented using an 1 1/2" vent pipe which must be vented to the open air so air can flow in and out of the vent pipe at all times. Also you might want to check for loose connection or waste water leaking from the pump, toilet or any of the connections.
May 21, 2010 | Saniflo & Saniplus& Macerator Pump
How can I minimise the smell of my macerator
The pump has a 1/2" breather hole and an 1 1/2" vent connection. The unit must be vented to the open air using the 1 1/2" vent connection, air must flow in and out of the vent pipe at all times. The 1/2" breather hole is only used for European installations. In the US you must keep it plugged or seal capped, if left open odor will emmit through there.
May 13, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
2003 ford explorer gas cap light stays on. Got new cap already
This means you have a small hole in the closed system. You need to go to a shop that has a "smoke" machine and that is how they find the hole.
The gas cap alert means the vehicle thinks the cap is missing because it is drawing air from a leaking hose. This does not mean you are leaking fuel, it means the vapors are escaping from the fuel system.
Apr 01, 2010 | 2003 Ford Explorer
Saniplus pump runs and pumps a cup of water and
unlikely to be a vent problem - more likely a semi blocked 22mm outlet - hence the problem with the old unit & the new one. Tricky to solve as 22mm pipe runs are too small for conventional pipe cleaners. Some plumbers use compressed air to clear, others us pressured water (jetter) unfortunately it always ends up a bit messy.
Feb 13, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
Runs good for about an hour, then needs 15-30 minute rest period
When it's about to quit, quickly undo the gas cap. If it roars back to life, you have a vacuum problem, where the vents aren't letting air into the gas tank to replace the used fuel, so after a while, gravity isn't sufficient enough to pull gas from the tank until is sits and equalizes for a while.
Jun 30, 2009 | Husqvarna Zero Turn Mower Z5426
Saniflo Sanibest macerator with multiple connections Logo
165 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
