Question about Sony Audio Players & Recorders
My cd player does not recognize discs.
My sony 5 cd player does not recognize discs. every once in a while it will but 99% of the time it says no disc.
  • 30 Answers
This could be several things , one would be the cd spindle motor, needs to be cleaned, if it starts out sluggish and then reads..it needs to be cleaned..this can as simple as spraying some contact cleaner into the motor
Posted on Jul 28, 2009
Why is my recorder reading disc as data disc
you can only record on disks that are specifically marked for 'digital audio' you cannot just use any blank cd-r disk
Aug 04, 2014 | Sony RCD-W500C 5-Disc CD Recorder
Player does not recognize any discs
please do simple process by simply cleaning the lens area with cotton swabs. please don't try to play any disk in try open stage, you may damage your player thanks gizmo
Dec 27, 2007 | Sony CDP-C505 5-Disc CD Changer
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
Kenwood CD-203 5-Disc CD Changer will not play CDs. It powers up and recognizes a CD within the slot, but it does not read the disc to begin playing.
The laser might be the culpert, be sure its clean by using a swab and a alcohol. If the laser is needed
it could cost approx $75 unless their using a Sony
which might be cheaper!
Apr 17, 2010 | Kenwood CD-203 5-Disc CD Changer
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
CD player does not recognize the cd's in the player
Hi, you will need to replace the optical lens assembly asap if possible. this is basically what the issue is at Thia's time. you can confirm my diagnosis by trying to clean the lens with a lens cleaning disc. if the cleaning dosen't restore the reading ability of the lens, you will need to replace the optical lens assembly when possible.
please rate and have a great memorial day:)
May 25, 2009 | Sony SCD-CE595 5-Disc CD Changer
3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Aug 01, 2007 | Yamaha CDC-565 5-Disc CD Changer
221 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
