Question about LeapFrog Leapster 2 Learning System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
  • 3 Answers
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Posted on Jan 31, 2010
Call 1 80 701 - 5327 for help
Posted on Jul 29, 2009
  • noranata Sep 23, 2012
    thanks it really help, the leapstar is back on for him. just bought it two weeks ago .
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
I can not type in names to activate this toy. I touch the screen and nothing happens.
I think you need to calibrate this toys:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Dec 24, 2010 | Leapster 2 Handheld Game
When I turn the leapster2 on in comes on fine. When it asks me to type in a name the touch screen pen isn't working. Nothing happens!
we have had this problem with our Leapster2 for a while. Found this solution this morning and it now works great! www.ehow.com
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
  • Read more: Best Way - Leapster 2 Troubleshooting | eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
    Aug 12, 2010 | Toys
    When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
    the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
    Feb 28, 2010 | LeapFrog Leapster 2 Learning System
    Leapfrog Leapster touch screen
    Press the ? button and hold it while turning unit on.
    Press the "a" button to select touch calibration
    Press each + with the stylus
    Restart machine
    Apr 10, 2009 | LeapFrog Leapster 2 Learning System
    Touch screen does not work
    2) Hold down the Hint button while turning the unit on
    5) Restart unit
    Mar 22, 2009 | Leapster Learning System
    Leapster can't read input
    You need calibration
    Touch Screen Calibration is as:
    1.) Ensure that a cartridge is NOT inserted.
    2.) Hold down the Hint (’?') button while turning the unit on.
    3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
    4.) Touch each of the crosshairs that appear with the stylus.
    5.) Restart the unit.
    Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
    The pen won't work on my daughter's leapster
    1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
    Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
    LeapFrog Leapster 2 Learning System Logo
    1,632 people viewed this question
    Top LeapFrog Toys Experts
    Nikki  Mclean
    Nikki Mclean
    thegtw
    relojmesa
    Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
