Question about InFocus Proxima UltraLight X350 Multimedia Projector
I have a projector that is powering up but there is no light coming from the lens. I changed the bulb and still the same thing. When it powers up it sounds almost like a harddrive inside is skipping sectors but I know it doesnt have a hard drive and I do not think it is the fan, any ideas?
  • 2,237 Answers
The colorwheel may be bad. if the colorwheel doesn't spin correctly, the lamp won't light. turn it on without the lamp in. look inside the lamp housing and see if the multi-colored glass disk (colorwheel) is spinning. if it isn't, or it's laboring, it needs replacing.
Posted on Aug 04, 2009
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
I changed the bulb and the power lights wont come on
Certain Mitsubishi projectors have a built in bulb life timer, and are programmed to not allow a projector to power on unless the bulb is replaced and the bulb life timer is reset. Its a simple process:
1) Make sure your projector is plugged in.
2) Make sure the main power switch is on.
3) Hold the left arrow, right arrow, and power button on the control panel of the projector (not remote) for 3-5 seconds.
4) Release...
This will reset the bulb life timer to 0000 and allow for normal power up barring any other unforeseen issues.
Mar 07, 2011 | Mitsubishi HC3000U Multimedia Projector
Changed lamp but when powering up ready light is on and lamp light, and when it powers up it goes to lamp light and never comes on. Any idea what problem is?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
have a nice day!
Jerry Lampdeng Limited
Feb 08, 2011 | Sanyo (6102932751) Projector Lamp for...
Bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
Apr 14, 2010 | Eiki LC X986 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
InFocus LP650 will not come on
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Sharp XR 10X lamp replacement issues
I sent mine in. They changed the bulb and cleaned the unit. The one thing they did suggest that seemed helpful was to upgrade the firmware. They did this as part of the service. That may be your problem, but I don't know that the firmware is upgradable. Yes indeed, they do charge an outrageous price!! I went through Sharp because they would guarantee the work, and I didn't want to buy two bulbs.
Oct 01, 2008 | Sharp XR-10X Multimedia Projector
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
InFocus Proxima UltraLight X350 Multimedia Projector Logo
133 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
