Question about Frigidaire FEB30S5D Electric Single Oven
Bottom element of my drop in oven(range) is not working
  • 3,037 Answers
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well, to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, then its bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the wiring and touch the probes from the meter to the contacts on the sensor. You can order a new sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
3 Suggested Answers
SOURCE: Top oven will not heat up
JKP55 The top oven would not heat. Got it fixed for $261.00 with tax. The bake element in the upper oven was bad. My oven unit is 14 years old.
Posted on Feb 07, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont lite or work
You say it will not lite ? I must think you have a gas range and you most likely have a bad ignitor. If the range is electric you may have a bad bake element. You can change this easily from inside the oven. Simply unplug the range, then inside you will see the bake element on the bottom of the oven. You will find two screws holding it in. Remove the two screws and gently pull the element out of the hole. I will have two wires attached. You can remove the wires by simply pulling them off, some will be screwed to the element. You can then check the element with a voltage meter for continuity. If you have none the element is bad. Hope this helps and feel free to call if you need further help.
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
Electric oven only works on Broil
just one light. if its not the element, then you could have the oven thermostat. check that
Oct 12, 2008 | GE JKP85 Electric Double Oven
Frigidaire FEB30S5D Electric Single Oven Logo
71 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
