Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Hard foot pedal
I have a Minkota all terain 40 lb thrust. My foot pedal has progressively gotten stiffer and now it very hard to push down. what's wrong and what can i do to fix it?
    Problem Solver:
  • 8 Answers
On the base of the foot pedal there is a tensioner for the cable. Try loosening or tightening that first. If you still have the manual from when you bought it, it is explained in deatil in there. It's a common issue - not to worry!
Posted on Sep 10, 2009
When i press the clutch pedal down it makes a rubbing noise similar to worn brake pads.stuart
opel vectra ,,,,ot sure if their is a automatic adjustment on the pedal ,if so it could be this failing which the cable could be frayed ,would really need to see it to know for sure
Feb 08, 2016 | Opel Vectra Cars & Trucks
My Singer Sewing Machine runs too fast. Is there a way to slow it down?
what type of machine do you have. I have two that I operate with buttons and it has a little slide button to speed or slow down I don't know why it should run to fast with a foot pedal because you control the speed with your foot you may want to check to see if there is any trash that has gotten in the foot and somehow not allowing the foot to come back up
Sep 10, 2015 | Singer Sewing Machines
What does error code F04 mean something with foot pedal? It is really hard to plug in. Could I put WD40?
the receiving plug would have something wrong with the pins in it or the foot pedal plug could have something wrong with the pins in it,, it would be better to have a sewing technican look at the machine.. don't use wd 40 on the plug
Dec 14, 2014 | Sewing Machines
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
I have a motor guide great white saltwater series 109 lb thrust 36 v trolling motor. I hooked the 3 batteries up right but it isn't running right, it's very slow. What do I do with the grey wire which has...
running to slow indicates voltage too low
you will have 3 X 12 volt batteries connected in series ( positive to negative to positive to negative with positive to motor The first battery negative connected to the ground on the motor
the multicore wire cable is for 12 volt draws as in fish finder, light etc and can be connected across any single battery terminals
They could also be for a foot controlled pedal that is forward and reverse operation
that will be explained in the user manual
Dec 06, 2017 | Car Audio & Video
1999 honda prelude manual transmission isn't disengaging all the way when i shift, sometimes locking the shifter in gear or not allowing me to up or down shift. I know my master and slave cylinders need to...
This depends as dose it do it when cold or hot.
2nd when you push in pedal and put in gear dose it go in clean or hard to select 3rd can you hear a grinding noise when pushing in pedal and noise goes
when you take you foot off the clutch pedal IF so then its the thrust bearing on clutch REPLACE ALL .4th if you push in clutch pedal and select a gear and let the clutch out if drive right out (replace)
Sep 27, 2009 | 1999 Honda Prelude
Dodge neon gas pedal problem
Not sure what spring you're talking about with the CAI. The CAI is just pipes and hoses, there shouldn't be a spring. Have you driven another 2002 neon before? I know with some cars, the gas pedals are a lot stiffer than others. My gas pedal on my Focus is a lot stiffer and more sensitive than my friend's aveo or civic. The spring I think you're refering to is probably the one hooked up to the pedal itself which is easy. Just pull out the old spring and put in a new one.
Aug 07, 2009 | 2002 Dodge Neon
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
368 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
