Question about Seagate 500GB Barracuda ES.2 SATA 3Gb/s Internal 500 GB Parallel Hard Drive
My seagate hardisk is damage & burn pannel
My seagate hardisk is pannel burn where to repair
    Novelist:
  • 81 Answers
If you go here http://tinyurl.com/seagateRMA you will be taken to seagate's RMA section where you can put the serial number into their system and get instructions on how to mail your bad drive back for a replacement assuming it is under warranty.
Posted on Jul 28, 2009
  • 89 Answers
If u are Bangalore go to cunning ham road there near reliance world there is a seagate office... or if not in bangalore go to the shop where you bought that hard disk and get it repaired
  • 746 Answers
Dear User! You can fix that problem by yourself. Take a bootable CD insert into your CD/ DVD rom and use seagate disk manager 2000. Use advance option and repaired your hard disk yourself.
Thank You
How to check my hardisk?
Seagate uses seatools diagnostic software for checking a drive...
http://www.seagate.com/support/downloads/seatools/
Sep 06, 2012 | Intel Computers & Internet
I was using seagate hardisk...after sometime it continously produces abnormal sound.I asked an expert and he said that my hardisk is dead.So i bought a new one.Now when i start my computer after some hours...
Possibly but if the noise is back again after replacing the disk, I would check into overheating. If you have access to an air compressor, blow out the case, fans, heatsinks, and power supply. Block the fan blades before cleaning fans as you do not want to over spin the fans which might damage the bearings.
Was the disk an external as your posting indicates? or an internal drive?
Jim
Preston Computer Services
www.prestoncomputerservice.com
May 31, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Warranty check for hdd
Seagate hardisk warranty can be checked from the following link
http://support.seagate.com/customer/warranty_validation.jsp?form=0
You must need Serial number model number and country where you purchased
Sep 01, 2010 | Seagate Computers & Internet
My harddisk drive is corrupted of damaged!!
Maxtor has merged and become Seagate. Here is the site for India warranty information:
http://www.seagate.com/ww/v/index.jsp?locale=en-GB&name=india-warranty&vgnextoid=47e815dfc9a86210VgnVCM1000001a48090aRCRD
Or just click HERE
Good Luck!!
Apr 03, 2010 | Maxtor Hard Drive
Turn on acer aspire 4315-2004 and nothing happens
wellcome,the hardisk may be damage and need to be replace ok.
Jul 28, 2009 | Acer Aspire One PC Notebook
Hard disk can not detect and giving beep randomly. hard diisk is from seagate and capacity is 80 gb
Hello there..i have experience with same problem like this...there is two problem with hardisk: first with the mechanic platter inside your hardisk ( you can hear noisy sound from inside HDD) 'cause by wrong prosedure when turn off the pc or problem with chipset on hardisk board (you can see the small green pcb board at other side of your hard disk) touch that board...if feel hot yes there is problem.this problem cause by electrical shock from your power supply unit or you not plugin correctly to hdd power socket.
solution for first problem :
send it to nearest seagate 'cause they have all the parts that you need
solution for second problem:
replacle the board with same tipe and size of your hdd..and it will work again and you can safe your data.but if not...nothing you can do it
Best Regrad
SHOGUN 125
Jan 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Oct 19, 2007 | Seagate Barracuda 7200.7 200 GB Hard Drive
Seagate 500GB Barracuda ES.2 SATA 3Gb/s Internal 500 GB Parallel Hard Drive Logo
193 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
