Question about Stanley Staple/Nail Gun Elec
How do i load a bostich e66760 stapler - Stanley Staple/Nail Gun Elec
5 Suggested Answers
  • 6 Answers
SOURCE: I can't load staples in a borrowewd SX150 stapler
check the crown size. some are 9/16 others are 1/2
Posted on Dec 01, 2009
  • 15139 Answers
SOURCE: Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Posted on Jan 18, 2010
  • 885 Answers
SOURCE: what part do I need
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Posted on Apr 26, 2011
  • 21 Answers
SOURCE: I HAVE A STANLEY BOSTICH ELECTRIC STAPLER,WHEN YOU CLOSE THE DRAWER WHERE THE STAPLES GO YOU GET A KNOCKING NOISE
I recommend that you will post your question under the correct category (Stanley Office Supplies) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Posted on Oct 22, 2012
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I reload staples into a Bostich Electric Stapler E66760? I tried standard staples and they won't seem to fit
RTM. Read the manual. If you didn't keep it, you can Google for one with your make, model and manual in the search box and you should be able to get a .pdf file of the manual which you can save to your computer. You're probably using the wrong size staples.
Mar 05, 2015 | Staples Office Equipment & Supplies
Bostitch stapler instructions
Google search. type in specs and diagram, should come up
Jun 28, 2014 | Office Equipment & Supplies
Oct 04, 2012 | Stanley Electric Desk Stapler, 45 Sheet...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
My bostich flooring staler wont fully drive every staple and it is getting wors....it is not leaking air
Your compressor needs to be checked first. There is an air pressure regulator on most machines - be sure all is in working order. It might help to be sure you're playing any lubricants in the stapler configuration as well.
Nov 05, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Have a Electric Stapler B8E E66760. Won't kick out to load staples
pretty simple. Take off the plastic cover, at the front where it staples will be a black metal piece on top of the stapling area. That is the front clip release. Release the staple tray like you would normally with the button and also Push the top black piece back to detach it from the staple tray. It should spring out then. Clean around it with alcohol and keep the cover off. Push it back in place, release it a few more times to make sure it works correctly now, then put the screws back in.
Oct 04, 2010 | Office Equipment & Supplies
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Aug 31, 2009 | Stanley Air Tools & Compressors
Stanley Staple/Nail Gun Elec Logo
927 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
