Question about Kenmore Elite 45986 Front Load Washer
Kenmore front loader not draining with a clicking noise
I ran a load of laundry small and when it was done the washer was still full of water. I took a measuring cup and bowl and got out as much water as possible. My husband pulled washer out and it is spinning and now making a clicking noise like it wants to drain.
Is there anything we can do or does a technician need to come out.... Help please have a soccer tournament this week and need washer.
Rachel
  • 5,911 Answers
Check your drain pump reservoir for any possible obstructions. That may be the source of the clicking noise. Probably something stuck in the pump impeller. The following link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If clearing the drain pump does not resolve the problem, you may have a damaged drain pump. If they do not pump at the correct volume, the washer will not complete a wash cycle. If this is the case, you will need to replace it. You can find replacements at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service and have competitive pricing, so shop all of the for the best deals.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 28, 2009
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Samsung Front Loader wf306law took off back panel as we had lots of water under neath ran washer rinse/spin soon as the cold water came in there was water all over the inside any idea why? the washer is...
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Jun 11, 2010 | Samsung WF337AA Front Load Washer
My GE spacemaker top loader will not drain, makes buzzing noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 3 front loader--water standing under drum at all times?
If you take off the bottom panel on the front of the washer, there is a little pump with a twist lid on it. Open that and see if there is anything plugging up the drain. We had a problem where a sock got sucked into it and it did the same thing.
Apr 18, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
227 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
