Question about Sony Cyber-shot DSC-W35 Digital Camera
Sony dsc t30
Dear Sir,
Re: momery stick
My camera indicates my momery stick has format error c:13:01.
What does it means?
I have a lot of pictures in the stick.
Also, my computer cannot open the stick as well?
Thanks
Alex
  • Ashrafhamdi Jan 07, 2008
    i've the same problem with the same cybershot camera
    pics also appear damaged
    plz help me
Arpi
  • 326 Answers
SOURCE: Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Posted on Mar 27, 2007
  • 51 Answers
SOURCE: sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Posted on Mar 09, 2008
SOURCE: DSC F707 Error C:13:01
If you really have a F707, it won't work with anything over 128MB according to this chart.
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCF707#m1
Posted on Aug 11, 2008
quang123
  • 107 Answers
SOURCE: Memory Stick error c:13:01
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Posted on Nov 30, 2008
SOURCE: memory stick error
This is a crazy fix but I can assure you it works, turn the camera off and hit it and then turn the camera back on, I had the problem and heard the fix and tried it as I had nothing to loose the camera was not working anyways an it fixed it error cleared.
You will laugh when it works.
Posted on Dec 08, 2008
Memory stick formatting error
try formatting the stick through the camera itself. else download the software of camera and connect it to pc and see if it has any formatting options...
Apr 01, 2014 | Sony Cyber-shot DSC-W120 Digital Camera
I'm unable to shoot movie on my sony camera dsc t90. when i press on record i get the following msg:system error c32:01 pse help
Error C:32:01 indicates problem with memory stick in camera, format memory stick through format option in memory stick setting option in camera setting menu and check.
If problem still not solved then put new memory card/ stick in camera as this memory card would be defective.
Thanks.
Dec 25, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
When i switch on my sony cybershot DSC-S30 camera
A letter and number error code of C:13:xx is an indication the recording media (floppy disk or Memory Stick® media) you are using is either not supported for use with the camera, not formatted properly, or is damaged or faulty.
Refer the links:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C356202&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=76702925&stateId=0%200%20180284222
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
Oct 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
When i turn the camera on it says format error and i cant take any pictures
Please take out memory stick from camera and power up camera and check still gives format error?
If no further error then put memory stick back in camera and press Menu >> Format >> OK to format memory stick. That will delete all data on memory stick and refresh it for new photos.
May 17, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Format Error keeps coming up when I try to take a picture
You need to format memory stick by going into camera menu.
Click Sony Support to download user manual of DSC-S700
Mar 18, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Taking Photo
Go to camera Menu and select Format memory option.
Format memory stick and file error problem would be resolved.
Oct 28, 2008 | Sony DSC-T30 Digital Camera
Please format memory stick by going to camera menu > format ption.
Oct 05, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Memory Stick Formatting Error - Sony Cyber Shot DSC T-20
I have had the same problem. Contact your camera via USB to your PC. Click on MENU. You do see "USB Connect" and "folder" at the bottom. Make sure that it stays on "USB Connect" click on round button in the middle and you will get 4 options. It probably stays on AUTO. Select PTP and see what happens. Adobe Photo Album started up and I got to see the pictures till the moment that the stick got the format error. I lost a couple of pictures, but got a lot back.
I'm not sure what the problem is, however realized that if this happens again. Shut your camera. Start it up again. Go into MENU, SET UP, Memory stick tool, chnage Rec folder and create a new. This way you keep the folders smaller and do not loose that many pictures.
I hope that it helps.
Pepe
Oct 30, 2007 | Sony Cyber-shot DSC-T9 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
