Question about Watts Onan Portable Generator - 4000 , Model# 5500
Wont keep running after start button is released
Rv onan 2800 lite generator , fuel filter and lines are good and was running fine the day before.
    Problem Solver:
I have a honda generator that is not putting out any ac voltage. It was working fine but when the power came on, it did not get unpluged and after that, I had no a/c voltage. How can I troubleshoot either the regulator or circuits?
Posted on Aug 14, 2009
If the fuel filter is good and lines are good then it sounds like the fuel is making its way to the carb built trash is stopping the fuel from getting into the engine in order to run. Clean out the carb bowl and clean out the valve stem. I know on the Honda unit the valve stem is removed with the carb bowl then then with a striaght screw driver you can remove the Body once you drop the bowl down with the stem so to clean out the cyclinderical body. Good luck
Posted on Aug 13, 2009
Onan 6.5 rv gen set starts buts dies when start button is released
First check the oil. If the oil level is low it will not run. If the oil level is good the generator may not be producing power and you will need to troubleshoot the generator.
Oct 27, 2016 | Electrical Supplies
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Onan 2800 generator sops when a/c is turn on
While you didn't indicate the btus of the HVAC I assume it worked before? What you are describing sounds like the engine isn't making horsepwer. A 2800 is a small unit that a HVAC and some lights is about all it can stand. The HVAC takes about 6 x current to start it, than it does to run it. If this inrush is high and the generator engine isn't producing full HP then it will shut off and die on under frequency. I would recommend having and engine leakdown test done (not a compression test, as that doesn't tell the whole story. This will ensure all valves and rings are mechanincally in good shape, then try a basix tune up, plugs filters etc.
Jul 23, 2013 | Onan Cummins 2.8 KV-FA/6050 RV QG 2800...
I have a onan 2.8kvd rv gen. replaced the pcd and it still does the same thing push the starter button in and hold to keep running
You need to make sure you have voltage from the stator windings, this feeds abck to the control board. Have the rotor and stator checked, and brushes and skip rings
Apr 01, 2013 | Onan Cummins 2.8 KVD-2090 RV QG 2800 RM...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
758 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
