Question about Compaq Presario S6300NX PC Desktop
I accidentally pushed the speaker cord into the audio card slot and the computer turned off and wouldnt turn back on but the screen said no signal input
  • Lrobby14 May 11, 2010
    Can you give me a little more detsail were you inside the compute is the computer plug in to a surg protector
    Problem Solver:
  • 5 Answers
REMOVE YOUR CMOS BATTERY AND THEN BOOT YOUR SYSTEM. IF IT IS BOOTING, INSERT THE BATTERY AGAIN ATER POWERDOWN
Posted on Jul 28, 2009
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
ET1161-07 onboard Video gone bad. I tried a Gforce 8800GS 384mb card, that works, and I have no video, 1 long beep that never stops. Ican't get into the bios with the onboard video or the new video and...
Hi.
One continuous beep means that you probably have not put the graphics card in the PCI express slot or there is a short somewhere in the system.
Follow these steps to try and resolve the problem:
Remove the power cord and the video lead from the back of the machine and then remove the side panel to reveal the motherboard.
Remove the graphics card and take a look at the PCI Express slot for dust. If you see any dust get a clean, dry paintbrush and clean the dust from the slot and then blow on the slot to remove the rest of it.
Next look at the brass contacts on the graphics card and clean then. Re-seat the card making sure that it is fully pushed down in the slot.
Check that any other cards you have installed in the machine are seated properly.
Without putting the side panel back on, connect both the video lead and the power cord and turn it on. DON'T TOUCH ANYTHING INSIDE THE COMPUTER!!!
If the computer boots up turn it back off and put the side panel back on. If not then please post back telling me what the computer is doing.
Good luck.
Jun 07, 2011 | eMachines ET1161-07 Desktop PC
Speakers have no sound
Please check the below mentioned things :
Verify the AC power cord is plugged into the wall outlet. Turn the VOLUME knob on the right speaker until you hear a click sound. An LED will light next to the knob when the power is ON. Turn the VOLUME knob clockwise to raise the volume. Check volume level on the computer sound card or alternate audio source device, and set at mid-level. Check plug connections on the audio source. Make sure the signal cables are inserted firmly into the correct jacks. Make sure the 3.5mm stereo cable is connected and fully inserted into the "line-out," "audio-out," or the headphone jack of the audio source. Test the speakers on another audio device. Remove the 3.5mm stereo cable from the audio source device and connect it to "line-out," "audio-out," or the headphone jack of another audio source.
And if in in case u r unable to get it working ..
Replace the speakers ..
Jan 24, 2011 | Altec Lansing VS2120 Computer Speakers
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
Need diagram for desktop acer 3100to replace sound card
Trace the cord from the speakers into your computers audio device. If the device is a small 1 inch'ish box attached to the motherboard, you cannot replace it without soldering experience with motherboards and if you had that experience you wouldn't be asking this question. If the cord from the speakers is connected to a card in one of your motherboards expansion slots (the place where you put new devices inside your computer) then simply buy a new audio card, open your computers, take out the old one, put in the new one, turn on your computer and after the operating system has loaded up it will probably ask you for the CD that came with the card you just purchased. If it is not automatically asking you for the CD, then insert it and run whatever setup or install program it has. That should do it.
Jan 04, 2010 | Computers & Internet
I accidentally pushed the speaker cord into the audio card slot and the computer turned off and it wont turn back on
On PC's, if Short Circuit occurs, the power supply shuts down.
  • Disconnect the PC for a minute and make sure no cable is stuck, reconnect. Then turn on.
  • If not. Check visually the power supply Fan on the back of PC and see if it moves.
  • If the fan moves for a moment, there's still a short circuit. In this case recommend a professional. If not move at all, it is more likely the power supply is gone.
Jul 28, 2009 | Microsoft Windows XP Home SP3 for PC
Audio card slot problem
Have you tried unplugging the tower from everything and leaving it for 5 mins? Then afterwards turning it back on? If that doesn't work, then there was a short near the audio port, and it may have shorted something out.
Jul 28, 2009 | Microsoft Windows XP Home Edition English...
What is the sound card and where is it
The sound card is more often than not integrated into your motherboard, check your device manager and you will probably have a realtek sound card. If so it is integrated, the only ones that arent are the Turtle Beach and Creative Labs Soundblaster models which are PCI expansion cards plugged into the motherboard. Ive never heard of manufactured computers using a soundcard that isnt integrated unless you paid for that upgrade.
Jul 15, 2009 | HP Compaq Computer Speakers
SHIFT-3-WIRELESS-INDOOR-OUTDOOR-SPEAKER
it comes with a transmitter. so put batteries in the transmitter and plug the included (white) audio plug in the back of the transmitter, (the hole that says direct input), turn transmitter on. Plug free end of audio cord into headphones jack on ur computer. put batteries in the speaker or plug it in to wall and push power button. push reset button on front of speaker and it should work. start playing music
Apr 09, 2009 | Audio Players & Recorders
Speakers not working
That means that the audio card is either faulty, or the driver software for the audio card must be reinstalled.
To find out if it is the software, reinstall the software using the computer install disk.
If you do not have the disk you can download the drivers from manufacturer website.
If the card is faulty, that is because unplugging in a bad way caused a short or broke the jack socket solder joint on board.
In that case buy a replacement
Either external USB : StarTech.com USB 2.0 to Audio Adapter Sound card
Or internal:6 Channel PCI Audio Sound Card Adapter for .
Audio cards are not expensive and you can buy a new one with a small fee.
Mar 22, 2009 | Computers & Internet
Compaq Presario S6300NX PC Desktop Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
