Question about T-Mobile Sidekick
My cell phone has been on the charger for over 8 hours and i have just recently purchased another battery and it still says low battery and to wait a few minutes and the phone will power on so what else can i do
    Brigadier General:
  • 3,614 Answers
This can be a problem on the battery terminal or the charging terminal of the unit. It could be the unit has not giving a proper charge or the unit has a problem when you try to charged a battery.
It is better to send the unit into the nearest service center to check the unit, and better not to charge on the for the moment it was not fix, to avoid any further damaged or burnt out on the unit.
Hope this helps.
Just let me know for further clarifications.
micr0-
Posted on Jul 28, 2009
My htc freestyle wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 05, 2012 | HTC Freestyle Smartphone
A brand new Samsung GT-S5233S is unable to charge low batteries. Salesman said the battery is too low and it can be charged only through universal battery charger. Any expert advice on this issue.
Hi. Thanks for using fixya.
The salesman is correct. Cell phone batteries need a "boost" sometimes when they are really dead. You can purchase a universal charger at a local store or order it real cheap on ebay. The battery will have to be charged outside of the phone.
Another way to get your battery going again is to put it in the freezer.
1)Place the battery in a seal-able plastic bag and place it in the freezer. This plastic bag protects the battery from condensation.
2)Allow the battery to freeze for 24 hours. Remove the battery from the freezer and allow it to thaw for 4 to 8 hours
3)Return the battery to the phone and turn the phone on. Make sure the battery is no longer cold before returning it to the phone.
This will revive your battery also. But for a new phone, I recommend getting a universal charger. U wont have to use it often. Its just to "jump-start" the battery.
I hope your battery works soon.
  • Jun 04, 2011 | Samsung Star GT-S5233 Cell Phone
    Need Help : Even after placing the charger into the (Motorolla V9 ferari) phone , it still displays " Battery Low , cannot program " Boot loader 05.80 SW Version R263313-AS_u_A 0.03.2FR
    the problem is from the battery.
    the battery is bad and needs to be replaced with a new one.
    so, go to a nearby motorolla outlet purchase a new battery, charge for an hour before putting ON the phone..
    NOTE; do not switch on the phone until the battery is properly charged.
    Jan 11, 2011 | Motorola Mobility RAZR2 v9 Cell Phone
    Am using iPhone 4, the battery was low (not fully drained) suddenly it went off & since that time i cannot switch it on & it doesn't turn on. My phone is almost dead for 2 days now.
    1. 1. Connect the Charger and wait for 3-4 hours. After that, try to turn the iphone.
    2. If not, try it on another charge Charger or usb port.
    3. If all else fails, you need to contact the service for battery replacement or repair.
    www.smartjet.mobi
    Nov 30, 2010 | Apple iPhone Smartphone
    2nd attempt----my a930 cell phone continues to discharge prematurally. Can get only a 2-4 hour charge. Batteries have been replaced. Do I need a software update ??
    1. What type of battery do you have is it a Lithium Ion or Ni Cad battery, Ni Cad batteries need to be completely discharged and then charged back up again, if its a Lithium Ion, your battery has memory cells in it, where it technically doesn't matter when you do it...but
    2. Charging habbits - How are you charging your phone, you should charge the phone when you first get it for a good 8-10 hours, the first charge is the most important, after that depending on what type of battery you have (see above) let it die and then charge it up for about 8 hours again, do this for about a week you should start to see significant difference.
    Also are you using a car charger or a wall charger, car chargers are NOT the best way to charge your phone, they used to get the job done, but not a perminate solution
    Apr 06, 2010 | Samsung SCH-a930 Cellular Phone
    My phone - dorado d800 -
    This means that your cell phone would be shut down due to Low Battery.
    Plug in the charger, wait for 15 minutes. Then try to ON the cell.
    If that doesn't ON, either Charger or Battery is not working.
    Change the charger and see if it works. If that works, perfect unless you need to get the battery changed.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 18, 2009 | Cell Phones
    Brand new motorazr V3s. draing batteries. only 3 hours of use
    HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
    Aug 16, 2009 | Motorola Mobility RAZR V3
    S-750DD
    Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
    Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
    T-Mobile Sidekick Logo
    164 people viewed this question
    Top T-Mobile Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Martin Murray
    Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
