Question about Dyson Vacuums
Screw size for dyson v8 wall mount bracket for v8 handheld vacuum charging station
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
  • 389 Answers
SOURCE: Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to www.dyson.com/support. Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
Posted on May 17, 2009
  • 430 Answers
SOURCE: I bought Hoover Wind tunnel central vacuum 2 weeks
There is a hinged bracket for this unit which has a 5" bolt through it. It comes from CanaVac who manufactures under label. If you cannot find this large U shaped bracket on the body or in the bucket, either return to COSTO or call Canavac and explain. A used bracket from an old Canavac will fit, nothing else will. If Costco is sold out you will not likely get one through a Hoover service center since they just don't break and it is a newer body style for Hoover made under private label.. A Canavac dealer might have one around
FYI if you got this unit at $200 off you got good value, if you paid full price and need to wait for a bracket, shop around for a different brand. While the unit and tools are good , the Hoover power head is the Achilles heal on this package. If you use it more than an hour a week , you will wear it out within 3-5 years as it is their light duty head.
If you have the bracket , hang the unit on a double stud if possible or 3/4 plywood braced across two studs. Leave 24-36 inches slack in your low voltage wire at the motor and coil around a pencil or long philips screwdriver, making it phone cord style... your wife and neighbors will think you are a pro......
Post back if you need more info.
Posted on Oct 16, 2009
SOURCE: what is the wall mounting screw diameter for a Toshiba 40xv645u
dude, im having the same problem - 5/16" wouldnt thread. I'm guessing they are metric - on my way back to Home Depot...i'll let you know what i find out.
Posted on Oct 22, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
Must I use the wall mount to charge the Dyson V8?
always charge any item that comes with its own charger that way you can not damage it by trying to charge it another way.
there is always other ways to charge things up but its best to use what it come with (more so for safety reasons)
Nov 30, 2016 | Dyson Vacuums
Can I charge the Dyson V8 without the wall mount therefore, by laying on its side? No wall space available.
Yes. The plug clips into the wall bracket and if you remove it you can use the charger just like any other. Alternatively just rest the V8 in the wall mounting bracket on the floor. I had no wall space either. I screwed my V8 to the back of the airing cupboard door.
What size Torx screwdriver do I need to fix a Dyson DC35?
go to the local tool shop and get a small set of torx bits
Jul 19, 2015 | Dyson DC35 Handheld Vacuum
How to fit wall bracket
Hi there, it's Jack at Dyson.
When installing DC59's docking station, use appropriate hardware/fixings for your wall type and ensure that the dock is mounted securely. Ensure no pipe work (gas, water, air) or electrical cables, wires or duct work are located directly behind the drilling area. The dock must be mounted in accordance with all local laws and regulations and applicable codes and standards. Dyson recommends the use of protective clothing, eye ware and materials as necessary.
The charger cord assembly attaches to the docking station as shown below:
I hope this information helps. If you need any further guidance, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Is it okay to store my Dyson handheld, DC 16, in the wall charger when not in use? I had heard that the battery life may be affected. Thanks for the helpful answer to my prior question. Phil Glasser
Hi Phil, My charger went bang and doesn't work anymore so my answer is after you have charged your battery remove it and switch your charger of and never charge a full battery. Has to be said also I would never buy another dyson product again, total rubbish.
Oct 29, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Ho to fix dyson dc16 base station to a wall
Here is a great video from youTube that shows you how to install the base station:
Jun 23, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Green light on DC44 but nothing is happening
Hi Emma, it's Jack at Dyson.
I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 01, 2014 | Dyson DC16 Root 6 Bagless Handheld...
How to hang a dyson DC16 base station on wall
Here is a great video that shows you how to install the base station:
Sep 10, 2012 | Dyson DC16 Root 6 Bagless Handheld...
Vacuums Logo
2,647 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
