Question about Canon FAXPHONE L80 Laser
It's not sending or receiving faxes, but line is working
    Brigadier General:
  • Canon Master
  • 3,614 Answers
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
micro
Posted on Jul 28, 2009
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Have two fax machines on two seperate broadband lines, both lines also serve internet/mail access which is working fine. Both faxes exhibit periodic/intermittent transmit and receive problems. Have had...
You can not send or receive faxes with any consistency on Broadband lines. You need an analog telephone line for these to work. Fax machines work on analog technology.
Jun 30, 2008 | HP Office Equipment & Supplies
Cannot receive faxs
The majority of non receive issues are phone line problems.
3 conditions must exist for a fax to receive, the phone line voltage must be high enough, the phone line current must be high enough the the DB gain must be correct.
A fax receive should be viewed in the same way a remote controle works.
When you send a fax, you manually access the phone line when you select send, you connect to the phone line, normally via a relay. Once that physical connection is made, it can send anything. Maybe not well, but it will send.
Where as receiving is an electrical signal that activates the machine. If your phone line is not up to standard, its like haveing a remote control with weak or dead batteries and trying to turn on your TV with those weak batteries in it.
Issues, simply a bad phone cord between the machine and phone jack. Some resistance may have acrured over the years. The phone jack itself may have a poor connection.
A staticy phone line will cause a fax not to pick up. Plug a phone into that line and see if there is any noticible static.
Multiple devices plugged into the phone line with the fax machine. ETC an answering machine, credit card machine, etc can cause more of a draw on a shared line, if that is the situation, at least for a test, remove everything but the fax machine from the line and see if it receives then.
Rarely if the machine can send and not receive is the machine an issue.
Have your phone lines checked well and that sould resolve the issue. And make sure the line is not plugged into the extension or phone jack on the machine, but plugged into the line jack. That is also a common problem.
Apr 30, 2008 | Office Equipment & Supplies
Fax machine will send faxes but will not receive any
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Apr 11, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Jan 31, 2008 | Brother MFC 420CN All-In-One InkJet...
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Canon FAXPHONE L80 Laser Logo
206 people viewed this question
old marine
old marine
