Hello. my room air conditioner unit is leaking water on the wall. what is the problem?
  • 534 Answers
Your condensation drain is clogged. Look on the outside of the unit there is several holes on the bottom that serve as a drain. You can take a wet vac/shop vac to vaccum the debris out to give the fluid a way to drain. Good Luck
Dave
Posted on Jul 28, 2009
Wall unit is leaking water
Hello, if this is a window unit water will leak for one of two reasons, either a blocked drain or the unit is not tilted back enough in the window.
Jul 01, 2012 | Fedders A3X05F2A Air Conditioner
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
Water leaks from the wall unit after it works on a cooling cycle for a short time. Seems there is no provision for the water to be piped away. The wall unit is situated on a dividing wall between two...
That unit was not designed to be installed on an "interior" dividing wall between two rooms. Only on an exterior wall. There in lies the problem.
Feb 03, 2011 | Heating & Cooling
Hello: When unit is turned on it starts to leak.
Either the unit is tilted toward the room or the drain holes outside at the bottom of the A/C are clogged.
Jun 20, 2010 | Heating & Cooling
Water leaking into room
Angle your unit so the back is lower than the front and the water will run out the drain hole on the bottom.
Sep 02, 2009 | GE Heating & Cooling
Leaks water into room
Try tilting the a/c to the back. In most cases the manfacture will seguest that the unit be tilted to the back slightely (no more that 20 degrees). That is what I would try. If that dont fix it let me know and we will try together and solve this problem. Good luck
Aug 24, 2009 | GE Heating & Cooling
A lot of water leaking out of A. C. into neighbor's window below
Place a flat piece of sheet metal or aluminum under the unit that is LONGER and Wider than the unit.....the water will drip on it and run down it and away from the building.
Aug 17, 2009 | Frigidaire FAC126P1 wall/window Air...
GE SPLIT UNIT
I would check the unit to ensure that it is draining towards the pan assy. should be 1/4" per foot.
May 29, 2008 | GE Quiet-Aire Ductless Heat Pump Split...
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
