Question about Cell Phones
My sony ericsson w580 cellphone shut of and wont come back on, when i press to come on it blinks a red light PS. was fully charge!
Unlock sony ericsson w580 unlock
Hi, You can unlock a Sony Ericsson W580 safer and easier using unlock code. You can get the accurate unlock code for your Sony Ericsson W580 from www.simpleunlocking.com/sony-ericsson-w580/rs16wp9/ at low cost. You can then visit www.mobileunlockguide.com/sony-ericsson-w580 This site provides free step by step unlocking instructions. This could help you understand unlocking process better,
Nov 29, 2012 | Nokia Cell Phones
MY controler wont turn on when fully charged and it does responed to the ps3
At the back top of the remote behind the 4 red lights there is a tiny pin-hole. With your PS3 on, press the big PS button on your remote, then push the button inside this little hole; a pencil lead may work. This is the only time you need to do this.
Good luck and please give me a good rating if i've helped you.
Don
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Cannot determine if my sony ericsson cellphone
Please press the button to the side of ur phone(It is there in most of the modela) you will get the status of the memory, battery percentage(charge remaining).
Hope this helps....
Mar 04, 2010 | Sony Ericsson T610
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
Jan 05, 2010 | Sony Ericsson K850i Mobile Phone
Sony erricson W580 doesnt switch on
They might b a software problem also hardware probelm ie the Eprom could be damaged this is the chip that contains the operating program if bad cant start.
Try installing its operating system program of the phone .
Jul 22, 2009 | Sony Ericsson w580i Cellular Phone
Sony ericsson w580i wont turn on light on side blinks red
Please visit the Sony Ericson technical shop, donot try to open because once the seal breaks, warranty gets over
Jun 16, 2009 | Sony Ericsson W890i Cellular Phone
Doesn't turn on, Red light blinks 6x
Make sure the battery is fully charged! And make sure, too the problem is not come from Power IC problem! then your problem is security damage and called GDFS in sony ericsson. For repair this you must make test point or buy LOG to write GDFS again. No need box or any equipments just usb cable.
Apr 09, 2009 | Sony Ericsson w580i Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
