My cell is not work properly.phone always start in offline mode.
when i try to select general profile in phone.i get a message"insert sim card"plz solve my problem.
Well turn ur fone off and charge it and after some time turn it on and try if does not work install new software on ur fone feel free to ask anything thanx alot.
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
I think you are using the handset without sim if it is so try inserting a SIM Card and while trying to switch on phone it will opt you whether u want to continue with offline mode or not.......simply click on no and your handset will be out of offline mode
But if you have inserted the sim card and its still showing offline try going to profiles and select General mode from there....if it is changed then its superb and if not then visit your nearest service center to get the software updated for your device
hi my n95 phone is in offline mode, when i select the general profile the massage is shown on the screen insert sim card.please help me how i can change the offline mode
when it turns of in offline mode, turn it off again everytime. after few times, it should ask you before the logo shows up "DO YOU WANT TO CONTINUE IN OFFLINE MODE?" SELECT NO, AND VIOLA. ITS IN GENERAL MODE
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
