Question about Microsoft Windows XP Home SP3 for PC
I accidentally pushed the speaker cord into the audio card slot and the computer turned off and it wont turn back on
    Scholar:
  • 103 Answers
On PC's, if Short Circuit occurs, the power supply shuts down.
  • Disconnect the PC for a minute and make sure no cable is stuck, reconnect. Then turn on.
  • If not. Check visually the power supply Fan on the back of PC and see if it moves.
  • If the fan moves for a moment, there's still a short circuit. In this case recommend a professional. If not move at all, it is more likely the power supply is gone.
Posted on Jul 28, 2009
Lost my sound when I moved my computer
Have you checked speakers on another computer. Get it checked first if it working on another computer or other device. If it working reinstall realteK audio drivers.
Nov 04, 2017 | eMachines ET1810-01 PC Desktop
Speakers on my Pioneer VSX-D466S receiver are not working. Is there an internal fuse that may be blown?
some recievers have a monitor button on them. if it gets pushed your sound wont work. look at the display and see if you see the work monitor. if so you should have a monitor button either on the reciever or the remote. it is a toggle button so just push it till it goes away and sound comes back on. make sure to turn sound back down before pushing this button as you might have turned the volume way up trying to hear it. my wife accidentally pushed it last week and she thougt is was broken untill i got home and simply pushed the button.
Dec 24, 2010 | Pioneer Audio Players & Recorders
I have lost all the audio on my desktop PC HP 511n. I have tried the troubleshooting advice provided by HP but to no avail. Can anyone help?
janem, due to the computer's age it would seem that HP no longer offers support.
I was looking to see if the audio driver, (Sound driver) was available from HP.
I am of the mind that downloading, and installing the sound (Audio) driver needed may be to no avail.
Uses the AC '97 codec made by Intel, and is probably integrated sound made by RealTek.
http://en.wikipedia.org/wiki/AC%2797
May not be the advice you're looking for, but I would suggest buying an inexpensive sound card, and installing it.
You need a PCI sound card.
This is one example;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3981743&CatId=2768
Installing:
1) Turn the computer on, ait until Windows has fully loaded. Install the CD disk that comes with the Sound Card, into the optical drive. (CD/DVD drive)
Load the software.
Once the software has loaded, you may be asked to Restart your computer.
NO.
Close all windows go back to your desktop screen.
Shut the computer down normally.
2) Unplug the computer from power. Advise disconnect the power cord FROM the surge protector, and Not the back of the computer tower. (Pulling the power cable out of the back of the computer {Power Supply actually), can cause a voltage spike)
3) Open the computer case:
Work on a table. (A bed or directly on a carpet floor is a HIGH area of Static electricity. Static can fry out (Short Circuit) the hardware components inside a Computer)
Remove all cables leading into the back of the computer tower.
If memory serves, looking at the back of the computer there is a single screw in the top middle, and one screw on each of the outside edges towards the bottom, to remove. 3 screws total. Philips head screws ( + )
The computer cover pulls forward, and comes off like a hood. The cover is a one piece affair of three sides. Top, left side, and right side.
Before you reach into your computer, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
It is also a wise move to de-static yourself before handling computer hardware components, such as the Sound Card.
De-static before taking the Sound Card out of it's protective anti-static bag.
Inside the computer's motherboard you will see three long white PCI slots.
Two may be occupied, but one should be free.
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
Line up the Sound Card's gold plated contact pins on the bottom of the card, with the open available PCI slot. The outside end of the Sound Card that you plug your speakers into, lines up with an opening in the metal frame of the computer case.
For this age of computer there may be a metal slot cover that is removable, by removing a single Philips head screw.
There may not be.
The metal slot cover may be held in by two, or three tabs.
Removing the metal slot cover in this case is performed with a pair of pliers, and a flat tipped screwdriver. Use Extreme caution when removing this metal cover, as the edges can be quite sharp!
The flat tipped screwdriver is used to push in one side edge of the metal cover.
Then the tip of the screwdriver is used to pry the edge out a little more, where finally the pliers can grab the edge.
The pliers are used to work the metal cover back, and forth to break the metal tabs, that hold the cover, and remove it.
The Sound Card's gold plated contact pins are lined up with the PCI slot, and the card is pushed down into place.
A single Philips head screw is used to hold the Sound Card in place.
Replace the computer cover, plug the computer into power.
All cables are reattached to the computer, to include the speaker cables.
WAIT 1 minute, turn the computer on.
Oct 08, 2010 | HP Pavillion s7420n PC Desktop
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
Need diagram for desktop acer 3100to replace sound card
Trace the cord from the speakers into your computers audio device. If the device is a small 1 inch'ish box attached to the motherboard, you cannot replace it without soldering experience with motherboards and if you had that experience you wouldn't be asking this question. If the cord from the speakers is connected to a card in one of your motherboards expansion slots (the place where you put new devices inside your computer) then simply buy a new audio card, open your computers, take out the old one, put in the new one, turn on your computer and after the operating system has loaded up it will probably ask you for the CD that came with the card you just purchased. If it is not automatically asking you for the CD, then insert it and run whatever setup or install program it has. That should do it.
Jan 04, 2010 | Computers & Internet
Audio card slot problem
Have you tried unplugging the tower from everything and leaving it for 5 mins? Then afterwards turning it back on? If that doesn't work, then there was a short near the audio port, and it may have shorted something out.
Jul 28, 2009 | Microsoft Windows XP Home Edition English...
What is the sound card and where is it
The sound card is more often than not integrated into your motherboard, check your device manager and you will probably have a realtek sound card. If so it is integrated, the only ones that arent are the Turtle Beach and Creative Labs Soundblaster models which are PCI expansion cards plugged into the motherboard. Ive never heard of manufactured computers using a soundcard that isnt integrated unless you paid for that upgrade.
Jul 15, 2009 | HP Compaq Computer Speakers
I was about to install a PCI sound card TM P1018 in my cpu. How will i do it?
Shut down the computer. Unplug machine Disconnect all peripherals from the computer. Remove the cover of the chassis and lay computer on its side if it is a tower. Remove the back panel, if necessary. Locate the existing sound card if there is one already installed. If it is screwed in on the side of the slot hole, unscrew it and pull the card out firmly. 8If the computer doesn't already have a sound card, find an open slot. 9Knock out or unscrew the metal plate on the card's slot holder on the back panel. Step10Insert the sound card gently but firmly into the slot. Rock it into position if necessary, but don't force it. Don't touch any connectors on the card. Step11Connect cables from the CD-ROM drive to the sound card. Step12Replace the back panel and any removed screws. Screw sound card into slot holder if it has a screw hole. Step13Reconnect monitor, keyboard, and mouse. Connect speakers to the sound card's ports. Step14Turn on the speakers and restart the computer. Step15If Windows detects the sound card upon startup, follow instructions to install the card's driver and additional software. If Windows doesn't detect sound card, manually complete the installation using the Add New Hardware control panel. Step16Play music CD to test sound card. Step17Shut down computer. Step18Replace cover of computer. Reboot computer.
Apr 24, 2009 | Computers & Internet
Speakers not working
That means that the audio card is either faulty, or the driver software for the audio card must be reinstalled.
To find out if it is the software, reinstall the software using the computer install disk.
If you do not have the disk you can download the drivers from manufacturer website.
If the card is faulty, that is because unplugging in a bad way caused a short or broke the jack socket solder joint on board.
In that case buy a replacement
Either external USB : StarTech.com USB 2.0 to Audio Adapter Sound card
Or internal:6 Channel PCI Audio Sound Card Adapter for .
Audio cards are not expensive and you can buy a new one with a small fee.
Mar 22, 2009 | Computers & Internet
Microsoft Windows XP Home SP3 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
