SOURCE: I have a canon 100mm EF macro lens with a loose
You can TRY to see if the screws are loose on the back of the camera around the rear element. Sometimes they look flush but need a couple of gentle turns to bring everything where it should be. If possible you should use a JIS (Japanese Industrial Standard) Phillips screwdriver so you don't strip the screwdriver head. Don't use too much force - these are precision instruments and only need a certain mechanical tightness - too much can cause harm.
Unfortunately, if it's not those rear end screws, you'll have to send it in to Canon. Fortunately Canon is very good about repairing lenses, even if they are slightly out of warranty.
Good luck
SOURCE: I have a Cosina AF Macro 100mm lens that I used on
you should be able to use that lens with it. As long as it attaches to the SLR body ok. The thing to be aware of is with better technology in the newer camera you may have AF issues with that particular lens.
SOURCE: How to remove fungus inside inner Tamron's lens
My phone every time I want to dowload any thing from the web it doesn't support
