Question about Tecumseh Garden
I have to much oil pressure it is a 15hp oil
I have to much oil pressure it is a 15hp oil pressure sys. it is pushing it out of valve cover and exhaust
    President:
  • 986 Answers
It sounds more like blow by instead of oil preasure being to high,you can do a leakage test to each cylinder that will tell the story
Posted on Jul 28, 2009
What does a po1259 code for a 2001 honda accord 3.0 litre, v-tec b-1 sys. failure mean
Here is the explanation from engine-codes.com
P1259 Honda Description
The VTEC system activates the VTEC solenoid valve by command from the powertrain control module (PCM), and it charges/discharges the hydraulic circuit of the VTEC mechanism that is installed in the valve system to switch valve timing between Low and High. The PCM monitors oil pressure conditions in the hydraulic circuit of the VTEC mechanism according to the VTEC oil pressure switch downstream of the VTEC solenoid valve. If there is a disparity between oil pressure condition in the hydraulic circuit that is determined by the PCM command, and the oil pressure condition that is determined by the status of the VTEC oil pressure switch, the system is considered faulty and a DTC is stored.
Read more: http://engine-codes.com/p1259_honda.html#ixzz3aiInXy9j
May 20, 2015 | 2001 Honda Accord
How do you repair oil coming out of the breather tube?
sounds like it is overfilled and/or you crankcase ventilation system is not working and pressure is pushing oil out. Clean replace PCV valve, ensute system can breath.
Sep 02, 2014 | Cars & Trucks
Severe oil leak
It could be a bad oil pressure sending unit, valve cover gasket, timing chain cover gasket or oil pan gasket. If there's white smoke coming out of the exhaust it could have a blown head gasket but it's not a common problem with that engine.
Jun 11, 2014 | 1997 Pontiac Sunfire
How do i know if i bent my valve stems buy rotateing my engine to do ther next push rod before it bled down
remove rocker cover and watch the valves come to the top after each rotation and you will see one or more not come up as high as the others ! compression gauge will tell you which cylinder , a pressure drop tester will tell you how meany valves leak ( with carbs and exhaust removed so you can see and hear which valves ) first test no oil on top of pistons then secound test with oil covering piston top and if any pressures go up then rings are also leaking ! most garages can do this for you !
Apr 19, 2014 | Motorcycles
Oil pressure leaks tapet cover
you may have broken piston rings and your sump is being pressurized and blowing the oil out
Apr 02, 2014 | 2002 Ford Explorer
Fuel in oil on 15hp B&G engine, what causes this
Get a fuel shut off and use it all the time! Your carb is probably like so many others that leak fuel constantly!
Jan 26, 2013 | Briggs & Stratton Garden
99 escort zx2 blowing oil on engine
Are you calling the oil pressure switch the oil solenoid ?
The oil pressure switch could have failed which would push oil out the terminal where the wire is connected.
Dec 22, 2012 | 1999 Ford Escort
How do you change the oil pump in a 1995 Lumina van with a 3.8?
REMOVAL
  1. Remove front cover.
  2. Remove oil filter adapter, pressure regulator valve and spring.
Fig. 16 Oil Pump & Housing 42162079
  1. Remove oil pump cover attaching screws, then the cover and gears, Fig. 16 .
INSPECTION
  1. Check pump cover and housing for cracks, scoring, porous or damaged casting, damaged threads or excessive wear or galling. Replace as required.
  2. Check pressure regulator valve for scoring, burrs or sticking in valve bore. Replace as required.
  3. Check pressure regulator valve spring for tension loss or bending, replace spring as required.
  4. Check gears for chipping galling or excessive wear, replace as required.
Fig. 17 Oil Pump Inner Gear Tip Clearance Inspection 42162080
  1. Measure oil pump inner gear tip clearance, Fig. 17 . Maximum clearance should be 0.006 inch.
Fig. 18 Oil Pump Outer Gear Diameter Clearance Inspection 42162081
  1. Measure oil pump outer gear diameter clearance, Fig. 18 . Clearance should be 0.008-0.015 inch.
Fig. 19 Oil Pump Gear End Clearance Inspection 42162082
  1. Measure oil pump gear end clearance with gear dropped in housing, FIG 19. Clearance should be 0.0010-0.0035 inch.
  2. Measure pressure regulator valve for valve to bore clearance of 0.0015-0.003 inch.
INSTALLATION
  1. Lubricate all gears with clean motor oil, then install gears in housing.
  2. Pack pump cavity with suitable petroleum jelly.
  3. Install pump cover and cover attaching screws. Tighten cover attaching screws to specifications.
  4. Install pressure regulator valve and spring.
  5. Install oil filter adapter using a new gasket, tighten oil filter adapter attaching bolts to specifications.
  6. Install front cover on engine. During front cover installation, ensure inner pump gear is properly engaged on crankshaft sprocket.
Jan 29, 2011 | Chevrolet Lumina APV Cars & Trucks
High pressure in valve cover pushing oil itno tubo intake. Any suggestions
Check ur EGR valve. It might have been blocked by dried oil or the connection hose is disconnected! It is a HOSE w/ valve connected into the intake manifold or the air cleaner housing! Hope that might help u!
Nov 18, 2010 | 2002 Volkswagen Jetta TDI
Lifter noise on a 4.8 liter chevy motor. do i need to pull the heads to replace lifters?
You usually don't need to pull the heads. I'm not exactly familiar with that engine but 50% of the time you can get a magnet and pull them out through the valve covers. But to make sure it's the lifters. Let it run until it's warm and remove the valve covers. You at that point should push with your finger on the push rod side of the tappet. If one of them ticks (you will be amazed you just did it with your finger) thats the bad one. However the whole cause of the problem with hydraulic lifter is oil pressure. The 0-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil. Thus lowering oil pressure causing the tick. It is normal for some LIGHT ticking to occur in the 4.8L and some noticeably louder ticking on startup. Good luck!
Jun 28, 2010 | 2005 Chevrolet Tahoe
Garden Logo
112 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
