Question about Hoover Vacuums
Am using the hoover for the first time, can I leave the battery in the vacuum when not used or must it be removed when not in use?
    Top Expert:
  • Hoover Master
  • 49,159 Answers
Leave it in
Posted on Sep 09, 2017
  • 7 Answers
SOURCE: Using vacuum attachments
??? What model do you have???
Posted on Jan 09, 2008
  • 126 Answers
SOURCE: Hoover Floormate has lost most vacuum capability
Check to make sure that the filter cover is in place. This is commonly lost or misplaced. It is a clear-blue plastic cover that lines up with the motor intake and acts as a link for the tank.
Also, check the squeegees and make sure they are not torn. If they are, they will not allow the suction to concentrate in the nozzle. Also, check the black plastic wheel assy under the machine. These are notorious for breaking at the pivot pins at the back and this will not allow the machine to sit on the floor properly and will contribute to this problem.
Posted on Jan 20, 2008
  • 190 Answers
SOURCE: drive belt burns up after every two vacuumings.
This problem happens a lot on this model the belt wheals get out of shape or strings get wrapped around them, Check the belt wheal by taking a knife and running it over the wheals to see if there is anything wrapped around them if so clean them off and clean any gunk that is built up in the space the brush roller fits in. Some times the strings wrapped around the roller will burn black and you cant see them that is why you need to take a knife over them to make sure there are none there and there is no gunk builds up on the belt wheal,
Posted on May 09, 2009
  • 52 Answers
SOURCE: SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
Posted on May 18, 2010
SOURCE: My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Posted on Jan 18, 2015
Should battery stay on charger after it is charged between use. This is for a Hoover Linx cordless vacuum
I leave mine on the charger until I use it mostly more than 8 hours after charged and in 12 months nothing has happened
that is why the charger is incorporated into the stand
Dec 29, 2017 | Hoover Vacuums
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
Hoover zen whisper multi cyclonic canister vacuum belt removal
just underdo the screws from the bottom of the hoover head (where the brush rotates from) I think from memory there are about 8 screws carefully price the plastic apart use a flat headed screwdriver as sometimes there are retaining clips and you should be able to access it hope this helps
Apr 05, 2014 | Hoover Zen Whisper Multi-Cyclonic Canister...
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
HI There,
Here's a repair that I did that explains step by step on how you can remove and replace the brushes on your Hoover SteamVac, I hope this is helpful to you. If you have any questions, please feel free to use the comment section in the repair here on Fixya, and I'll be happy to answer any follow up question that you may have.
Here's the link:
Please leave feedback for me if this helped you fix your problem, thank you very much
Chris Jones
Apr 28, 2010 | Hoover F5858-910 SteamVac Vacuum
Using the hoover steam vac for the 1 st time and it was borrowed from a friend but no manual was provided...just need to now where exactly the water goes in the bottom or the top?
The clean solution with the shampoo mixed in goes into the top tank, and when you **** up the water it goes into the lower tank.
Here's a link to the manual online that will show you precisely how to use this machine. If you have any questions, or need help with something else, please don't hesitate to use the clarification request form here on Fixya.
If you found this helpful, please be so kind as to rate the repair and leave feedback. This is what keeps fixya experts to continue to post free repair advice here on Fixya. Thanks so much, this is greatly appreciated.
Chris Jones
Apr 16, 2010 | Hoover F5810 SteamVac Upright Vacuum
Uses a "type Y" Hoover bag. Hope this helps, if so, leave feedback when asked. Thank you, Rene(the Vacuum Doctor)
Nov 09, 2009 | Hoover Vacuums
How do I replace the drive belt in the hoover u6401?
Remove the plate from the vacuum's underside. You will see fourscrews or two clips that attach the plate to the vacuum. Removingthe plate will give you access to where the belts are running. Remove the old belts and replace with new belts. The hoover self-propelled models use two different belts. One is a flat belt Hoover #38528035 and the other is a V belt Hoover #38528034. You can find these belts at on these pages:
Oct 14, 2009 | Hoover Vacuums
Instructions on Using The Hoover Steamvac Ultra cleaner
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
Carpet and Upholstery Detergent
Instant Stain Remover
Carpet and Upholstery Spray
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
