Question about Proform Exercise & Fitness
The console of my treadmill displays time and speed incorrectly
The console of my proform 380E treadmill displays additional lines in numbers when showing speed and time. Otherwise the machine seems to work correctly. Is this a console or a sensor problem?
  • Anonymous Mar 24, 2014
    the speed on the console displays incorrectly and jumps around
    Champion:
  • 208 Answers
Hi. if you are talking about the same segment in all the characters of your display being lit, then it is a console problem - it will not be a hard thing to fix but you will need a board level electronic serviceperson to do it for you
Posted on May 07, 2010
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
I have a Proform Treadmill XP550 that will not decline. I have tried all of the recalibration solutions on here, and reset and unplugged it several times. I opened up the cover and nothing seems to be...
use the software calibration for easy diagnostic and fix it. God bless you
Sep 17, 2013 | Proform Quick Burn Pro Treadmill with 12...
Hallo, I have a problem with my PROFORM 760 AIR, and when it takes 3 or 4 minutes. for themselves, or when X passes also for speed.
tes the speed sensor. RUN the software calibration for troubleshooting and fix it. God bless you
755de5d2-2307-4164-9313-a5be55a48396.gifVersion:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Apr 04, 2013 | Proform 760 CrossTrainer Treadmill
1125i proform speed fluxuates
Run the software calibration for troubleshooting. Test the s. sensor for open or faulty .clean it and tight very well.
God bless you
Feb 19, 2013 | Proform Crosswalk 500 Treadmill
Proform 860 runs at top speed even when safety switch is out
Run the software calibration for easy troubleshooting and fix it. God bless you
Calibration for "Newer Style" Consoles
The Calibration sequence can generally be used to accomplish the following: 1) To reset the treadmill's speed software, if the running belt seems to be moving faster or slower than the speed indicated on the console. 2) To reset the treadmill's incline software, if the walking deck seems to be elevated higher or lower than the height indicated on the console. 3) To synchronize the treadmill's electronic package ANY TIME a replacement part (anything electrical) has been installed and is being prepared for use. 4) This should be the first step performed when attempting to diagnose or troubleshoot the unit.Calibration often helps in correcting minor "bugs" in the software (by "resetting"), before actually having to replace components.
Before You Begin:
You must first determine the model number and style of unit of the unit being worked on. Do this by:
  • Powering up the treadmill and removing the emergency stop key (usually a magnetic plastic piece that attaches to the top, center of the console). If you see "10" in the console, it is an old style console and the "Older Style" Calibration should be referenced. If an "SI-1" appears in the console, it is a newer console. The following calibration sequence can be performed.
Note: To change any of the current codes (if incorrect or out of sync), use the SPEED + or SPEED -(minus) button(s).
Refer to the Calibration Chart (or the unit's owner's manual if not on the chart) to verify that the calibration codes on the unit (represented as "??" below) are correct.
Feb 08, 2013 | Proform 860 Competitor Treadmill
How do I calibrate speed on a Proform 725TL treadmill
follow the steps that i am giving now.
God bless you
Jan 10, 2013 | Proform 725tl Treadmill Drive Motor
PROFORM XP 580 NEW PART MC2100 IS NOT THE SAME AS OLD PART
you must to return the parts and demand for the original part for your right treadmill,
Otherwise you must waste your time and money.
Be sure if you are doing the right with the machine,
Test aNY Fuse,c.breaker , REED switch, sensor speed,. Test all connector tight very well included the ribbon cable for keypads for display board.
Jan 07, 2013 | Proform Crosswalk 500 Treadmill
My Proform 380E has only been used about 5 times since we bought it. I turned it on the other day to actually use it and the belt won't move even though I can hear the motor running and the display shows...
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
Watch this video.
1) observe if the main motor is running, be carefull with you hands.
2) See the drive belt motor is o.k or is broken and replace+ or flywheel is loosen or broken too.
3) Test if the motor is turning with good speed adjust speed. Test the speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
Apr 12, 2011 | Proform 380 CS Treadmill !
Proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
May 21, 2010 | Proform ZT5 Treadmill
Treadmill displays incorrect speed. I always run at 4.2 MPH. Today, with the switch in the same position, the display says 6.6 MPH, but the belt is turning at the same 4.2 MPH. I tried unplugging unit...
Treadmill is more than likely in metric. Most mill (if in english measurement) will start out at .5 metric usually star at .8 Not sure how to change for treadmill but it should be in the manual.
Jul 26, 2009 | Proform Exercise & Fitness
Exercise & Fitness Logo
305 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
