Question about Kenmore 22422 Top Load Washer
Code hd won't reset
I had a power outage few days ago and the washer now has code hd (which means the lid is open, according to book) lid not open have turned off and on several times, unplugged, and reset breaker? any advice thanks robin
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
We have LG top load waveforce washer showing error code dL. At start there is a few seconds noise then error code appears. The washing cycle does not start. What is the problem and how do I fix it.
most likely a Door Lock error. means that the door lock is not working. fairly easy replacement if necessary. might check the lock first to make sure it has connector plugged into it. and that nothing is jammed inside of it. good repair videos at repairclinic.com and appliancepartspros.com or online at youtube.com
Oct 30, 2016 | LG Washing Machines
Hello Blessing Today!!! Please Need activation Code for pch gwy#6900+4900 Claim by Rena Br.
Need to cancel Gillian Batten from the booking and cannot ...
www.fixya.com/.../t26022119-need_cancel_gillian_batten_from_bookin...
3 hours ago - Need to cancel Gillian Batten from the booking and cannot do it ... PleaseNeed activation Code for pch gwy#6900+4900 Claim by Rena Br.
My WWF score is 2 games out of date. Anything I can do to ...
www.fixya.com/.../t26022099-wwf_score_2_games_out_date_anything...
3 hours ago - Within the last few days, I won 2 games for which I have not been .... Please Need activation Code for pch gwy#6900+4900 Claim by Rena Br.
How do i make a new password for my email - Fixya
www.fixya.com/support/t26022047-make_new_password_email
5 hours ago - I have new email address, cant Login and written serveral times ... PleaseNeed activation Code for pch gwy#6900+4900 Claim by Rena Br.
What code is +813 or what country - Fixya
Dec 25, 2015 | Computers & Internet
Any time I go to start the washer the lid lock button starts blinking and wont start cycle and wont open for ten minutes
Hello. This could indicate a problem with the electric lock. Unplug the washer for a few minutes to reset it and see if that clears up the problem. Have you had a power outage recently(3-4 weeks) prior to the problem? The current surge from the returning power can damage and/or corrupt the programming stored in the main board computer. If you have never experienced the technical part of a washer, please call for service--there are many problems which can cause this symptom. The washer will have to be put into a diagnostic mode to decipher the binary error codes(groups of lights will flash, telling what part of the unit is problematic). I hope I helped you!
Aug 23, 2015 | Whirlpool Washing Machines
How do I open a locked lid on Kenmore elite top load washer 796.2927 that has no power?
That washer is actually built by LG even though it has the kenmore name brand on it most all are the same for opening the lid when its stuck like that below is a video that shows how to get it open and then if you need more detailed help you can visit the link below the video.
Fixing an LG Top Load Washer DOA and Lid Stuck Locked
Appliance Repair Help With Live Chat
Mar 26, 2017 | Kenmore Washing Machines
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Code E12 (?) after power outages, got it working again but is stuck in heavy duty mode only.
A power surge may have blown out or shorted any one of the many components in modern washers. Seems silly but I've fixed many error codes by unplugging mine for a few minutes from the wall and re plugging it. Hope that helps. Otherwise you could call the manufacturer and ask for the meaning of the code its self
Apr 16, 2014 | Frigidaire Washing Machines
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Please tell me how to correct error code OP. My lid is not open and it was properly working just a day ago.
press clear or cancel button ,any errors in washer can usually be fix by this. if not unplug it fro few minutes and plug it back in.
May 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 22422 Top Load Washer Logo
18 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
