Question about Jenn-Air JCB2280HES Side by Side Refrigerator
My Jenn-air refrigerator is freezing up everything and we have changed the setting of the temperature?
  • 66 Answers
SOURCE: The Freezer freezes...and so does the Refrigerator!
your thromstae is bad
Posted on Feb 06, 2008
  • 1122 Answers
SOURCE: jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Posted on Jun 23, 2008
  • 29 Answers
SOURCE: Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Posted on Jan 28, 2008
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
meBNme
  • 334 Answers
SOURCE: Temperature control does not work. Unit freezes
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Posted on Oct 12, 2009
Why does Our refrigerator keeps freezing everything? Even the food in the drawers are frozen. Why is that?
Check the cold control thermostat setting maybe you set it to max. put both controls on middle of whatever numbers you have on them and if its already on middle or at minimum setting still it freezing everything you need to replace to Cold Controller Thermostat
Aug 23, 2014 | Jenn-Air JCD2295HES Side by Side...
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
Vegetable drawer freezes items
Adjust your thermostat / temperature setting to a warmer temperature.
You could also have a lot of food placed in front of the vent in the top of the refrigerator compartment. Tall jugs (like milk jugs) are usual culprits of this one. Cold air is deflected in other direction, it might be going straight to the crisper rather than diffusing first.
Jan 04, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer freezes, frige wont cool
Sounds like the fridge have a damper control broken or it is frozen and can't open to blow some air to the refrigerator area. Perhaps a thermostat failure. Hard to say without looking at it.
Try to lower the freezer temperature and check if some air goes to the refrigerator side. If so, the damper control may be freezing and needs to be replaced.
Dec 18, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
You can set the temperature to a lower position. Sounds like the thermostat is broken.
Oct 30, 2009 | Jenn-Air JCB2280HES Side by Side...
I REPLACED THE DEFROST ASSY COMPONENT ON MY JENN-AIR REFRIG, BUT STILL WON'T COOL ENOUGH. fREEZER WON'T FREEZE side by side jcd2289
Make sure both fans are running and check that your the coil is not frozen. The coil is behind the freezer panel.
Jul 02, 2009 | Refrigerators
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Refrigerator freezes things the freezer works fine:
Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air Refrigerator JCB2059GES freezes
Jun 23, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
456 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
