posted by Walt88 on Nov 22, 2007
Dishwasher drain pump keeps pumping. Dishwasher turning itself on and running forever. Delicate/Econo button flashing when tested.
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 16, 2008
I have the same problem when using regular wash.
Solution #1
posted on May 11, 2008
that usually happens when there is water in the base of the dishwasher where the motors are. Check to see if there is water in the base. This will trigger a float that turns off the water and on the drain pump.Remove the water and it should fill. However note that water came from somewhere, so find where it is leaking.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch 24 in. SHX36L05UC Stainless
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Bosch 24 in. SHX36L05UC Stainless Steel...
Bosch Stainless Steel...
model E-nr sm17052us/08... Answer This...
Dishwasher doesn't fill/How to...
Set the washer to run its... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
Find Parts
