I only see two screws where bag goes
SOURCE: replacement screw roomba discovery brush
You can try some large hardware centers. Maybe they can match one up for you.
You can visit the link below and contact them if you want to order original parts, and if your unit ever needs to be serviced.
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/home.php?clear_cookie=1
Jerry G.
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
SOURCE: Kenmore upright vac model 33922 - good suction but
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Ebay may have them if not try thefind.com
