Question about Ricoh Aficio 1035 Copier
Password for User Tools
I work for a not-for-profit that recently had an Aficio 1035 donated to it. I have been able to set up user names and codes through the User Tools panel, but I cannot figure out how to require a password to get into user tools. Right now I can just press User Tools, navigate to the user codes and, if I didn't know them all already, write them all down and use any code I wanted. Is there a way to force a password when the User Tools button is pressed?
I have the manual, but I haven't found help on this in there yet.
  • don6650 Jul 28, 2009
    I finally found the solution for this in the manual. I was looking for the wrong wording...
    There is a Key Operator Code under Key Operator Tools. Once that is turned on and set, the code is required to view and/or edit the various account codes.
  • 31 Answers
Go to www.savin.com (I used savin because the 1035 is the same as a 2535 or B003), go to downloads, select manuals, select B/W Digital and 2535/2545, select the System Settings manual, download it and on page 48 it tells you how to lock out the Key Operator settings.
Posted on Jul 29, 2009
How to find out where to read meter on my ricoh aficio 1035 copier machine
Ricoh Aficio 1035 have two meter those are the electronic counter and the magnetic counter type but they are program to synchronize. to look for the magnetic counter just open the front door and you will find it at the middle and to open the electronic counter just press the user tools/counter key located on the upper left side of your operation counter then press the counter on the LCD display. Hope this helps, thanks for using Fixya
May 03, 2011 | Ricoh Aficio 1035 Copier
Lanier LD040 How do I add an email address to be used by the scanner?
You can try this:
Press "User tools"
Press "system settings"
Press "Key Operator tolls" and press "next" (bottom right on the touch screen)
Press "Address Book Managment"
Press "New Program"
(Set the user information):
Press "Change" on the right of the user name.
Enter the name and press "OK"
Now on the bottom press "E-mail"
Press "Change"
Enter the E-mail and press OK
At last press OK (up right) and your done.
Hope you understand. Bye
Mar 04, 2011 | Ricoh Aficio 1035 Copier
How can I change the ip address for Richo Aficio 1035, I want to access this machine for printer use through my internet hub. Can anyone help please. Thank you
ok mate. follow the steps below to change the ip address.
-press user tools button
-press system settings icon
-press interface settings and you will see the ip address section, click on it and you can change it.
Nov 27, 2010 | Ricoh Aficio 1035 Copier
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Nov 25, 2009 | Ricoh Aficio 1035 Copier
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Aficio 1035 web interface user name and password
The Default factory passwords are not what you have listed. They are the following:
User name: administrator
Password: password (or possibly leave blank)
Give that a try.
However, the web interface isn't all that special on this older model anyway. All you need to program are the Ip address, and subnet mask, as there is no scan to email function, and the scanning can only be done via a software, that you won't have, and is getting difficult to find, because it is no longer supported, and just as complicated to configure should you find it ("Scanrouter V2 Lite" is the name ) as opposed to direct scan to folder. By the way this scanning software is NOT Vista compatible should you find it.
If you can't log into the web interface....on the machine, go to "user tools', "system settings", Interface settings", and set your IP address and subnet mask...that's it.
Please rate response :)
Mar 24, 2009 | Ricoh Aficio 1035 Copier
My Ricoh Aficio 1035 is not seeing the network
You will need to assign a new appropriate IP address for the machine under "user tools" system settings", "Interface settings", "Ip address".
Then create a new tcp/ip port for the printer, and point the old driver to this. Scanning may require additional work -perhaps a tech, to reconfigure the scanner. Your probably using the "scanrouter" software?
Jan 22, 2009 | Ricoh Aficio 1035 Copier
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Asking user name and password in Ricoh Aficio MP2000 copier
Pull the litium battery off of the printer card and put it back in. That may reset the password unless it wrote it to the hard drive.
Nov 20, 2008 | Office Equipment & Supplies
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
374 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
