Question about Dell Precision M60 Notebook
Laptop New LCD Screen Cycling Colors
My sister recently tripped and feel on my laptop making the screen only have usable other wise everything else works fine. So I got a new LCD screen and it just cycles though colors: black, white, grey, green, red, blue and so on. I returned the screen and had a replacement sent, but still the same problem. I just don't know whats up because both my broken screen and an external display work normally.
  • 558 Answers
Check the connection to the motherboard,as well as the connector to the inverter board.Make sure the lcd cable connected to the lcd is plugged in properly.
Good luck
Posted on Sep 29, 2009
    Scholar:
  • 177 Answers
It's probably the wrong screen, cable ,or inverter; in spite of what the repair shop tells you .
Also, sometimes the cable gets pinched if not installed carefully, or the cable connector may need to be re-seated.
Is your laptop a Dell Precision M60 ? I'll see which screen it's supposed to have.
Posted on Jul 28, 2009
  • Albert Benjamin
    Albert Benjamin Aug 01, 2009
    The DELL part number for your screen is :Y0316 **B. the original manufacturer part number is: Samsung
    P/N: LTN154X1-L01
Display
The LCD panel is physically broken and can not be fixed. It can only be replaced. Somehow it got cracked. Sorry for the bad news...
Dan
Sep 12, 2008 | Computers & Internet
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
Just like that my laptop got some color light vertical lines on the screen i can do everything but those lines are on my screen when I conect to a external monitor VGA CABLE i can see it fine ,... can...
Well it seems to cracked LCD issue or motherboard has gone bad.Hp would charge $398+taxes and Geek Squad would charge $524.99.So decide wisely or go with my Personal Suggestion...Now its time to move on and Get a new Laptop for yourself...
Dec 03, 2010 | HP Pavilion dv6000z Notebook
Screen has black blotches/spots
This could be due to a bad video card, but is much more likely to be a problem with your screen itself. What you described is likely to be caused by damaged or dead pixels in the screen. The cost of one is usually about half of the cost of the laptop itself, so you may want to consider buying a new laptop and salvage your data and other usable parts from this one.
Apr 26, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Acer 3000 Screen not working properly
This is most likely either a.) the connection to the LCD is falling out or b.) the screen itself is going bad.
If you feel comfortable to tackle this job you can buy the LCD to replace:
New LCD Screen:
http://www.lcds4less.com/AcerLaptop__acer_aspire_3000_series__laptop-screens.html
Removal Instructions:
http://www.lcds4less.com/PDF/Laptop-LCD-Removal-Instructions.pdf
Be sure to double check with the company to make sure that this screen will work with your notebook.
If you computer is still under warranty or maybe you purchased an extended warranty the manufacturer might cover replacement of the LCD.
hope that helps!
Jan 28, 2008 | Acer Aspire 3000 Notebook
Dell Precision M60 Notebook Logo
653 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
