Question about George Foreman 10042 Indoor Grill
Need to replace lost greise trap pans and spachulas
Where can i get replaced greise trap and spachulas that where lost in a move
  • 368 Answers
Hi gonefishin,
Start by going to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, or if you have questions, please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Posted on Feb 07, 2009
My Advantek trap for squirrels does not trip correctly anymore. Animals (rabbits) are taking the bait but the trap does not close. How can I fix this?
I had a similar problem and found that debris had accumulated along the pin at the bottom of the trip pad and limited movement. Pick the trap up and clean away all material from bottom of the trip pan. Then spray pin and connections with WD-40 and move the pan back and forth till it operates smoothly. WD-40 is made from fish oil and will not deter pests. Also check the wire hook that attaches to the top screen to set the trap and make dire it isn't bent and will fall off the screen easily.
Hope this helps.
Feb 14, 2017 | Hunting
How do you set to work
Hi, I'm Peter. On this style of live trap the solid lid you see on one end is the door that falls when the trigger is tripped. There is usually a couple of heavy wire rods that is attached to the outer end of the door that is connected at a swivel point and an arm that leads down to the "dog" on the side of the cage about midways. This is just a bent piece of metal that rest on another bent piece of metal that goes through the side of the cage to the bait ( Trip/ Trigger, Pan ) You lift the door up and when you do the arm with the bend down by the side of the cage will be in position. While holding that 1st bent arm move the second bent arm that is attached inside to the bait pan, into position to rest against the 1st arm. It will look like two fingers bent at the last knuckle hooked to each other. I put the bait on the pan inside before I set it. The animal will go in touch the bait pan with it's mouth or paw releasing the two bent arms that are held together by the weight of the trap door. This allows the door to fall trapping the animal in the cage. Most of these traps have a carrying handle on top but you MUST be EXTREMELY careful when carrying these traps because if it gets to close to any part of your body or a finger gets too near for example you will get bit or scratched by a highly irritated confined scared animal. It may take a couple of tries to get use to setting it without the door falling but don't give up you will get the hang of it.
Jun 16, 2014 | Advantek 20041B Catch and Release Live...
How does it work?
Put bait on the pan inside then on the side of the trap there is a trigger mechanism where one arm rest on another arm that holds the doors open. When the animal messes with the bait the 1st arm will move allowing the 2nd arm to fall closing the end doors.
Apr 09, 2014 | One Stop Gardens 32-1/2 L x 10 W x 13-1/4...
How do you set this trap
There will be a trigger mechanism on the side of the trap. When you raise the doors the trigger mechanism has two points where one will rest on the other holding the end doors open. I would recommend putting the bait on the trigger pan before you set the trap. When ever the animal touches the bait it causes the one arm to move in turn allowing the second arm to fall closing the doors trapping the animal.
Dec 04, 2013 | One Stop Gardens 32-1/2 L x 10 W x 13-1/4...
1996 volvo 850 pcv valve location
These have a PCV oil trap, not a valve. It is located under the intake manifold. The hoses run from under the spark plug wire cover all the way down to the oil trap and over to the throttle body. Over time the PCV oil trap becomes brittle and clogged. You will need to buy a new PCV kit for around $150 and replace it. Before you do, you must clean out the engine block where it attaches at its lowest point on the engine. I used sea foam, compressed air, and a coat hanger. I did an oil change at the same time so I could drain the sea foam out of the oil pan. Make sure you clean it out good because it will spray oil out of the dipstick and oil filler cap even after replacing the PCV components.
Apr 13, 2012 | 1995 Volvo 850
The refrigerator in my new home is Roper RT18DKXFN01, a 1997 top freezer about five feet tall. Should I be pulling out pans from the bottom and cleaning them? If so, I can't get it to move - is there some...
Hi ; Not an expert on this fridge,
You do not need to clean the coils
But at the back of the fridge , there should be a water trap sat on top of the compressor that is linked to the fridge via a pipe.
It allows condensation to run out of the fridge to the trap, where the heat from the compressor evaporates it.
Its possible that food waste has travelled down the pipe into the trap and is creating tha bad smell
You could also check the back for anything else that may have arrived by default and is causing the smell
Not sure if it has a special way to move it : But its a heavy object , so a little extra force may be needed.
Take care and good luck
Apr 21, 2017 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
We have a weather king select 90plus not really sure of the model number but when we turned it on it was running fine then all of a sudden the outside temp was 90 and inside temp was 81 and it could get...
Is this an upflow furnace? If it is, there needs to be a "P" trap in the condensate drain line. You need to check to see if there is. A "P" trap is a "U" shaped
tube or fitting in the condensate drain line. The first time you run your unit, run it about ten minutes then shut it off, the condensate should drain from the pan and fill the trap. Then you just turn your unit back on and let it run.
If you have a trap then you probably have a cracked drain pan and it will usually need to be replaced.
Jun 10, 2010 | Heating & Cooling
Leaking AC condensate drain pan
Check the drain line for possible plugged trap. Blow back through it in some way to try to clear it.
Jul 05, 2008 | Heating & Cooling
Pvp pipe from drip pan is not draining what can i do
If the water is backing up clean out the drain line or replace it. Code requires a trap and traps catch dirt and plug. Would be nice if they put a clean out on these but it does not always happen.
May 27, 2008 | Goodman Heating & Cooling
Need A Replacement Paddle
I have 2 breadmachines 1- K6745 & 1-welbilt ABM2H60 model. The paddel for the latter should work in the k6745. The female shaft of paddel is a little short but should do the trick, I think. Both machines have the normal type loaf pan, and the paddel did fit onto the shaft, so maybe looking at another machine w/ same style of pan will work also.
I really enjoy my K6745 but in a move I lost my manual could you e-mail a copy to me?
Aug 27, 2007 | Regal Ware K6745S Kitchen Pro Bread Maker
George Foreman 10042 Indoor Grill Logo
189 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
