Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Is it UHF or VHF
Motorola ht1000 model number HO1SDC9AA2BN. Itss only one letter difference but is it uhf still?
  • Motorola Master
  • 1,654 Answers
This is a UHF radio.
SDC is 450-520 MHz.
RDC is 403-470 MHz.
As you can see the two bandsplits overlap in the common 450-470 MHz range. If your frequency is between these numbers either of the HT1000 models will work for you.
FYI: VHF has the letters KDC usually.
Posted on Jul 28, 2009
I NEED TO KNOW WHAT FREQ. RANGE IS ON THIS SERIAL # 777FWLE408
Sorry, the serial number does not tell the frequency band of the radio. From this serial number I can tell you it is likely an SP50 radio, and it wwas produced Nov. 1996. You would need the model number to know the frequency band. The model number of an SP50 radio beginning with P93 would be VHF, and if P94 it would be UHF.
Note: With the mandated change to narrowband by Jan. 2013, only SP50 radios with a 00 (double zero) in the model number will do the new narrowband. Those models on wideband would have a 20 (twenty) in the model number. Example: P94YQT20AA2 would be a wideband UHF radio.
Best regards.
Aug 17, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
How can i tell if i have a uhf or vhf motorola cp200
The model number for a VHF radio has a letter K in the position where a UHF radio has a letter R. For example,
AAH50RDC9AA2AN = UHF while
AAH50KDC9AA2AN = VHF
Jul 19, 2012 | Motorola CP200 Two Way Radio
Programing Motorola HT1000
The HT1000 is a dealer programmable unit. The DTMF keypad on the front of the unit would be nonfunctional unless you were using it in conjunction with a repeater system which allows for DTMF phone capabilities. Otherwise it is just an extra place for dust, dirt and moisture to get in the radio. If you are working as a firefighter, it is highly recommended you get a holster to cover the front of the radio to prevent moisture from getting to the component board through the keypad area. As for telling if the radio is VHF or UHF, typically the 4th digit of the model number will tell you. If it is an R it is UHF; if it is a K it is VHF. Here is a link to a reference chart: http://www.batlabs.com/visar.html#5
Jul 02, 2009 | Radio Communications
Is it uhf or vhf?
Model H01SDC9AA2AN:
HT1000 UHF 450-520 MHz, 8 Channel, 4 watt, Portable Radio
May 06, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How can i tell if i have a UHF radio or VHF radio
You can use the model number to tell if you are VHF or UHF. You will still need to know the frequency(s) and PL code(s) your radios have to get radios to match.
VHF model number starts with P93.
UHF model number starts with P94.
The current replacement radio for the SP50 is the CP200. It is construction grade and was made to replace the SP50. There are other radios which will also match the SP50 including (but not limited to) the BPR40 and the new CP185.
Apr 28, 2009 | Motorola Talkabout FR50 (14 Channels)...
Uhf or Vhf that is the question
UHF. To receive calls in your car, the radio would need to be programmed to a frequency matching other radio you are wanting to receive transmissions from.
Mar 10, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How can i tell
Post the model number from the serial number label. We can look it up for you.
Aug 07, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
159 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
