Question about Grilling
Traeger BBQ Model 155.02 operator's manual - how can I best obtain?
    Top Expert:
  • Grilling Master
  • 45,918 Answers
Try Googling (Traeger)(155.02)(manual) without parens.
Posted on Sep 09, 2017
3 Suggested Answers
SOURCE: Traeger BBQ trips circuit breaker
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the hot rod igniter (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
Posted on Apr 12, 2009
SD Tech
  • 14553 Answers
SOURCE: Manuals for products below.
Best way is to contact Denon either on their internet site or by calling--method also: Google the model number for each with "manual" to see if available on internet.
Posted on Jun 17, 2012
When I start my Traeger grill it heats up and the temperature continues to climb and I'll not stop until I turn it off. Can you give me some information as to what I can do to fix this problem.
Ron, I am not real familiar with this model. If the temperature controls are not doing the trick, see if it has vent doors that can be slid open to help control heat. If it does not have vent doors, consider adding a couple to the top lid of grill. Link below how they work and install, you can also make your own quite simply.
BBQ Grill Burner Air Vent Installation and Adjustment Instructions
Apr 04, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Louisiana BBQ grill trips circut breaker
You need to take other devices off that circuit. Also outdoor circuits usually are on a GFI circuit.which are very sensitive to flucuations.
Jul 14, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Need part number for BBQ option to replace griddle
You will need the model number & serial number which may be on the back of the cooker on behind the plate under the oven door, then contact the manufacturer or agent. Reece HVAC are also a very good source to obtain parts from.
May 07, 2014 | KitchenAid KDRP463LSS Dual Fuel (Electric...
Traeger bbq problems
This is a common problem if you're trying to cook when its cold outside. Traeger sells insulating blankets for grills that are being used at 35 degrees or less. However, it could be an augur alignment problem that's keeping the augur from dunping enough pellets in the firebox. Here's Traeger's FAQ for that problem.
Q. I've been noticing that my grill temperature keeps dropping lower. What is the problem?
A. You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
You probably should contact Traeger customer service at http://www.traegergrillscom to confirm that this is your problem.
Apr 04, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Control board for BBQ 070
Contact Traeger customer service at http://www.traegergrills.com for parts and installation instructions.
Mar 30, 2014 | Traeger Industries Grilling
Jun 16, 2012 | Audio Players & Recorders
Jan 16, 2009 | Traeger Industries BBQ070 All-in-One Grill...
Grilling Logo
79 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
