Question about Minolta bizhub 200 All-In-One Printer
I have a message that says "Change PC Drum". What is that?
  • 4 Answers
This is telling you to replace the "DRUM" of the printer. This is different from the "TONER". Normally, the drum is attached to the toner cartridge. Check your printer documentation. You may be able to purchase a drum/toner kit. Drums last longer than Toner cartridges so you will replace the Toner cartridge more often than the Drum.
Posted on Jul 28, 2009
    Sniper:
  • 108 Answers
That model uses a Drum unit. If you open the right cover of your machine you will see a green cylinder that will be your drum. A technician will need to replace the drum unit and developer, run the setup and clear the counters.
Posted on May 15, 2010
2 Suggested Answers
SOURCE: "Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Posted on Nov 08, 2008
Change pc drum
Press bediener - details - stop 00 - stop 01 - enter 00000000 then touch end. Go to Counter- Counter Reset (higlight the six box) - function - f8 - press the start key (wait) go back to counter - pm - highlight ic life or pc life - press cancel button.
Hope it can help you.
May 29, 2013 | Minolta bizhub 350 Black and White Copier
I have a message, please change the pc drum. how i can fix it?
This message means the pc drum life is over. You should call service center to replace the drum and reset the message (if you are not a technician).
Oct 05, 2011 | Konica Minolta Bizhub 362 Copier
Need to replace drum?
Since drum is a life span part, once certain counter is reach, message will pop out. Well, if the machine is running in good condition, just ignore it.
Jul 29, 2009 | NEC Office Equipment & Supplies
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
1. Open the front cover.
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Minolta bizhub 200 All-In-One Printer Logo
382 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
