Question about Cub Cadet Garden
Cub cadet LTX1046VT white smoke and gas coming from exhaust when first started.
  • Rodney Carroll Feb 02, 2018
    I agree with some of the other comments. Carb may not be cutting off fuel when mower not in use. This happens a lot when the owner does not run fuel out of carb before storing at end of season. As mentioned before, it is a good idea to install a fuel shut off valve, if at least from having to drain the tank at the end of the season. This is really only a temporary fix. Probably need to clean or replace carb. A real danger exists if fuel gets into crankcase as a result of fuel flow not shutting off. Motor could seize or on rare occasions, explode due to excessive fuel in the crankcase.
    Maintenance if a very good idea too. Regardless or the cost, I would replace plug, filter, and oil at the beginning of season of use. If you can find a station in your area that has "real" gas instead of gas that has an ethanol mix, that would be a tremendous help in that fuel will not break down as quickly.
    Good luck.
  • 37 Answers
Bad needle valve or float dumping gas in crankcase and thinning the oil
Posted on Feb 09, 2018
  • 20 Answers
If it is not affecting the starting or running, then it is most likely not a carby / fuel issue. White smoke is oil, usually caused by over filling, In older engines it can just be seepage past the rings while sitting around, or oil getting sucked from the sump through the breather pipe during running but not enough to notice. Some will drip into the manifold while sitting around and be burned off when first started. Nothing to worry about.
Posted on Feb 06, 2018
  • 294 Answers
Lots of good answers. But in my opinion your problem is probably just a dirty air filter element. The dirty air cleaner can cause a vacuum in the carburetor that will pull in: 1st, too much fuel; and 2nd possibly a little oil from the oil breather tube.
A little gas gas smell and white smoke is is not a big deal on an older engine.
Constant white smoking is a major issue.In that usually the engine is in need an overhaul, the oil is leaking around the piston rings and/or valve seals. In that event often it is cheaper to buy a new motor than to rebuild the old one. Look online from Harbor Freight or others.
Posted on Jan 31, 2018
  • 32 Answers
White smoke is indeed burning oil. From my experience with my small 1042ii it is indeed oil. Where is it coming from. Check your valve cover on the sides if the engine. One or both are leaking. The while smile is from oil on your exhaust manifold and when it burns off, no more smoke. Look and see.
Posted on Jan 22, 2018
  • 125 Answers
I recommend a fuel shut off valve installed in line and shut it off just before you turn off the engine . I will say your carb needle seat seeps and does not shut off fully this causes white smoke and gas smell at start up i also recommend you change you oil after you install the shut off valve
Posted on Jan 21, 2018
  • 4 Answers
I would try inserting a gas shutoff in the middle of your hardline and shut it off when not in use. You can purchase one for s few dollars. At least try this first before moving on to checking the valves.
I think some of those Kohler 23HP air cooled twin cylinder engines had a oil splash-shield modification recall and you might want to contact your dealer about the recall that Kohler had for that issue.
Posted on Jan 16, 2018
    New Friend:
  • 22 Answers
Check the oil level. White smoke is oil Bruning. Nothing else causes white smoke. Black smoke is over rich fuel mixture most common caused by a blocked air filter in a lawn mower. Over filled oil levels are the most common cause of white smoke. Ironically a blocked air filter can also cause the issue as the engine tries to draw air through the engine sump breather tube and in doing so inhaled oil. If you can tick those of as not an issue the engine is probable in need of new rings.
Posted on Dec 03, 2017
    Master:
  • 379 Answers
Sounds like your Cub Cadet needs a complete tune-up (new air filter, sparkplug, choke adjust, etc).
Check your compression for piston ring seal. Do this by screwing a compression tester into the sparkplug hole and turn it over a few times.
You should get at least 90 PSI or more.
125 to 130 PSI is better (check manual for specs).
A low compression reading means your cylinder(s) and rings are worn allowing oil and crankcase gases into the combustion chamber. My guess this is your problem.
I suggest save your pennies towards a new mower.
Alfred Schrader
Posted on Oct 13, 2017
  • BensonMobileAutoRepair&Welding
    I agree that the piston rings need servicing and the intake gasket may be leaking also...too much oil will cause piston rings to fail
  • sreenivask
    sreenivask Dec 15, 2017
    it may be also adulterated oil if engine stops
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Relax! This is a common thing with modern lawn-tractor engines and no cause for concern if the smoke clears up within a couple of seconds after the engine starts. When you shut off the engine, a bit of gas is trapped in the cylinders and condenses as the engine cools. Then, when you start it cold using the choke, the engine is temporarily "rich" and a puff of smoke comes out. The smell of gasoline is caused by the same issue; some of the raw gas is expelled during the first few exhaust cycles and you get a whiff.
Posted on Oct 06, 2017
    Habit-Forming:
    New Friend:
  • 16 Answers
Most lawnmowers don't have a radiator and run by magneto. If your getting white smoke and fuel coming out the exhaust it sounds like it's burning too rich. Your spark plug is probably wet and fouled. The carb is too rich letting too much fuel in the cylinder. Note being on a slightly rich side is better than too lean. But not to the point your dealing with. Start with the carb and make sure it's clean and mixture is set right
Posted on Sep 20, 2017
  • 708 Answers
Carb. Needs needle valve or float repair to keep fuel from flooding. If it does not have shut off valve in fuel line from tank to carb. Install one and ALWAYS close when storing between mowing. .
Posted on Sep 10, 2017
  • Charlie Gibson Feb 09, 2018
    You will also need to drain the oil
    New Friend:
  • 12 Answers
White smoke, depending how much and how long it lasts, could be from simple overnight condensation in the exhaust system = should disappear once warmed up. Or, if the smoke doesn't go away, you could have a blown head gasket which is allowing anti-freeze and water into your cylinders.
Check your radiator / reservoir to see if the level has dropped, or if you are having to add water to it. If so that means (for some reason - Cracked Block ?) the water is getting in.
  • 48 Answers
SOURCE: I cant start my cub cadet cc989
sounds like a plugged high speed jet
Posted on Oct 24, 2008
  • 1779 Answers
SOURCE: white smoke coming from exhaust when accelerating
This is usually an indication of a bad head gasket.I gasket. The white smoke is the coolant leaking out of the engine and winding up in the oil passages, due to a bad head gasket. To confirm this,
1. check oil. Is level increased, or milky appearance?
2. Is coolant level dropping, but u don't see any signs of leaks?
The above indicates a bad head gasket, causing the white smoke u describe. Let me know how u make out.
Posted on Jan 03, 2009
  • 195 Answers
SOURCE: White smoke coming out of the exhaust when starting?
Hello;
Volumes of white smoke is an indication of water in the exhaust. A certain amount of vapor will be present on start up, but if it is different than what has been the norm for this vehicle then a check of the cooling system is in order.
Rich
RPM Northwest
Posted on Mar 25, 2009
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
ILikeBMW
  • 117 Answers
SOURCE: Blueish white smoke comeing from exhaust
Hello There
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Black smoke is caused by a rich fuel condition.
Blue smoke is caused by oil consumption.
You need to check your oil cap for yellow/white gunk on the cap if you have this then this is a sign your head gasket is cracked. Check to see if your radiator coolant level is down this is also another sign.
Hope this helps. Please don't forget to rate me.
Many Thanks
Posted on May 20, 2009
What does white smoke coming from a cub cadet lawn mower mean
Most likely the valve seals or the rings are bad and the engine is burning oil.
Oct 06, 2014 | Cub Cadet Garden
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Blowing white smoke
use a good gas additive and non ethynol gas
should clear it up
Dec 07, 2013 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
Aug 07, 2012 | Cub Cadet Garden
Engine started smoking cloudy thick white from exhaust on Cub Cadet SLT 1550.. maybe stuck or bent vavle any clues?
first check the oil for a gas smell and being overfull the needle valves don't always seat and the gas drains into the crankcase if not that do a compression test if it is low the head gasket might have blown out and its sucking oil from the crankcase the split on the side
Jul 10, 2012 | Cub Cadet Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
2005 Cub Cadet RZT 50 dark grey exhaust smoke upon start-up, plus some smoke when blades are engaged. Muffler gets very hot, and the engine seems to choke somewhat. The remote choke lever is opening and...
It sounds like it is very likely you have gas in the oil. This happens when the needle valve in the carburetor is leaking gas thru and into the crankcase. That will have to be repaired and the oil needs to be completely drained and refilled before running. Another thing can be done as a temp fix and that is to place a fuel (gas) shutoff in the line and turn off when not running but the oil has to be changed. Hope this helps you.
May 01, 2017 | Cub Cadet Garden
I have an early 90's cub cadet rider and it was over filled with oil. Now it smokes and blows oil out the exhaust. Could over filling it cause this? If not are there any common causes of blowing oil
Yes, over filling can cause this. The fix for this is to put the oil level back to normal, and run your machine normally, until the oil residue burns back off. Some "side effects" may be fouling spark plugs and occasionally residue build up in the muffler, so, keep this in mind. Normally, though, everything goes back to normal. It's better to run the machine for a while than starting and stopping it, to allow the machine to get up to operating temperature and clean out the exhaust system.
Best regards, --W/D-- please feel free to rate this solution.
Jul 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
714 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
