Question about Jacuzzi Home
Hello ,I just bought a house with a maax collection jacuzzi tub manufacturer date says 2005... when I flip the wall mounted light switch the panel lights up in red with --- then I get C02 and it shuts off ..no sound or anything
SOURCE:
  • 7 Answers
SOURCE: whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
Posted on Feb 02, 2009
  • 152 Answers
SOURCE: Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 10865 Answers
SOURCE: I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Posted on Apr 02, 2010
SOURCE: Garden jacuzzi tub start button is stuck. It won't pop back up
I called a plumber. He said push the button all the way in, put some 3 in 1 oil on the inside (you'll see a little indent) every couple of months. Also push and release the button quickly. Cost me $80, and he even used my oil!!!!
churchill
Posted on Apr 07, 2010
Where do i find the product number for my maax steam shower? i am trying to order parts. is it on the showerhead? it is the only place i see anything written as it was already in the house.
There is a heating unit somewhere that produces the steam. There should be an access panel somewhere to allow maintenance and repair. It could be in the tub surround or it could be behind a false door under the vanity or it could be in the wall depending on how you bath is laid out. Look for a panel with some screws.
Nov 19, 2017 | Maax Home
Model identification
While the brand of the tub may be of importance to you it may not be important when finding parts for it.
Bath tub manufacturers do not make anything that goes into their tubs i,e. the jets, pumps and controls are all purchased from various Mfg.
Are you have any particular problems with either unit that would make you need the brand of either?
Rod
U S Parts Center
Jan 05, 2014 | Jacuzzi Home
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Nov 19, 2009 | Maax Breeze: Two Piece Round Shower Module...
WHAT DOES THE WARRANTY COVER
It all depends on the manufacture, Jacuzzi, Aquatic, Maax. They all have different warranties and what is covered. Best to call or e-mail the manufacturer of the tub with the date of pruchase and serial number.
Aug 27, 2009 | Maax Kashmir Hydromax Whirlpool with...
Feb 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Dec 12, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Home Logo
57 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
