Question about Dryers
My whirlpool dryer model number LER4634JQ1 is not getting hot
My whirlpool dryer model number LER4634JQ1 is running but not getting hot it has the duel 20 amp circuit breakers are they strong enough to run it properly?
  • Dryers Master
  • 8,220 Answers
You need a 30 amp breaker in my neck of the woods. South Alabama, US
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2009
SOURCE:
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
My aunt needs basic operating instruction manual for whirlpool dryer mdl ler4634jq1
Hello your manual can be found here at this link click here http://www.managemylife.com/mmh/owner_manuals/17474/WHIRLPOOL-Residential-Dryer-L0710453?brand_name_search=ler4634jq1 if you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your search for you dryers manual. By doing this it allows me to continue helping others in similar situations in the future. Thank you,
Rick
Oct 01, 2011 | Whirlpool LER4634J Electric Dryer
My dryer does not start when i hit the start button. I have checked power to the dryer, it is good. I have taken my digital multimeter, to check start button, that tested fine. I checked all connections on...
It is probably one of the limit switches inside the dryer most likely the high limit went bad and will not allow the dryer to run or the door switch could have gone bad these are two very good places to start check the door switch first and if that checks out I would check the high limit.
Jan 17, 2010 | Dryers
My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
Old avocado green Whirlpool Dryer, door switch?
dryer gets hot 4 awhile then gets cold
Aug 16, 2009 | Whirlpool Dryers
I have a roper electric dryer that runs, but will not heat and the timeR will not shut off on any cycle. My model number is a LER4634JQ1 Can you help?
Your timer is fused. have it replaced immediately. it has failed.
You must also replace the hi limit thermostat and thermal fuse as well.
Aug 13, 2009 | Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer does not spin
Usually if a dryer won't spin, I suggest checking the belt to make sure it isn't broke or even the motor burned out. If you post a model number for your dryer, I may be able to assist you further.
May 28, 2008 | Dryers
Dryers Logo
274 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
