Question about Bosch SHU3305 Dishwasher
Removal of worktop top to machine
How do I remove the top to my machine so that I can get it under my existing work top
  • 88 Answers
its like your cabnit draw
lift litle up when that all is up
Posted on Aug 16, 2008
0 characters
1 Points
I can't see how to remove the worktop of my Bosch dishwasher. I found two screws that look as if they stop it sliding forward but I still can't move it after removing them. It looks for all the...
Hi john_mchugo,
The dishwasher Worktop can be removed by first removing the 2 screws at the back of the machine. The screws are either fastened horizontally, or vertically. Once these screws are removed, the worktop slides backwards, and can be lifted up and off.
On some models there are catch tappets located on the rear right and left hand sides of the Top panel. To remove the Top panel, press up the catch tappets, push the worktop back and lift it off. If these tappets aren't pressed up, the Top won't release at all.
I hope this has helped you.
Kind Regards
* If this solution helped you, please accept it
Aug 18, 2011 | Dishwashers
Water not getting hot. If it is the element can it be replaced in situe? eg without pulling the machine out from its position under the work top?
YOu can try and check if there is a connection fault on the heating element or if the element is faulty but to replace the element you will need to pull out the dishwasher from the worktop.
Unless the panels are removed, the top, the front and the sides you cannot get access.
Also a work must be done only with proper viewing and so the washer must be taken out.
Jul 26, 2011 | Whirlpool Dishwashers
The brackets to hold the dishwasher back under the counter do not align with the holes that were drilled in the granite counter top for the old dishwasher. I do not want to try to drill new holes in the...
You could have a handy person make some new brackets which attach to the new dishwasher's brackets with bolts but are made so that they line up with the existing worktop holes. You can probably use strips of soft metal with holes to fashion these.The dishwasher may have to sit slightly lower.
Dec 30, 2010 | Dishwashers
My left hand side door cord has broken, how much of the machine do I need to take apart? do I need to pull the machine from under the counter top?
Yes you will have to move from under worktop and then remove the side panel that the cord has broken.It may be worth checking the other cord and replacing both if worn.Also check if something is catching to cause the cord to break.
Hope this helped.
May 16, 2010 | Baumatic 23 in. BDW9 Built-in Dishwasher
I have a neff S5049X, pump keeps runing on even with door open, trying to remove it from underneath worktop to tilt back. How do I lower the legs to allow clearance between floor and worktop. What is the...
Sounds like the anti-flood device has kicked in this would suggest that there is either a leak under the machine or if you may have used too much rinse aid and it has frothed up and leaked under the door.
The screw in the middle is to lower the middle rear leg turn it towards the down or minus sign normally anti-clockwise.
Hope this helped.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
Whirlpool / IKEA Dishawasher DWH B10 - castor wheel
make sure there aren't any screws through tabs at the top front of the washer that fastened it to the counter top.
Jan 04, 2010 | Dishwashers
How to adjust the legs
Remove any plinth in front of the base of the machine. In the middle of the base you should see a black screw head with arrows either side. This screw adjusts the height of the machine at the back - clockwise = up and visa versa. The two feet at the front screw in or out of the base moulding to raise or lower the machine. Check that these have not been secured by screws through the front moulding. If so, slacken or remove. NOTE: make sure if the machine is already installed that you have loosened the screws which secure the machine at the top to the underside of your worktop.
Mar 01, 2009 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Steam eating my cabinet top up
You can buy a metal strip with a small angled edge to fit under the worktop above the dishwasher. I have one of these and it has protected the worktop for 10 years,
Dec 22, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
AEG Dishwasher 35080VI inbuilt - door pops open
usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Sep 02, 2008 | AEG Dishwashers
Aug 16, 2008 | Bosch SHU3305 Dishwasher
Bosch SHU3305 Dishwasher Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
