Question about JVC HD-52G786 52" Rear Projection HDTV
Lamp light blinking, Power Light blinking, TV off
I have the same issues, but was able to get the TV on by pressing and holding the power button longer. I've had to do this on a few occassions.
After holding the power button longer, the blue power light goes solid, screen comes on, while orange light continues to blink. After several minutes, orange light goes off and everything looks normal till the next time, next day likely.
Everything looks great when the blinking lights are off.
Does anyone have an electronic manual that references the blinking light?
  • JVC Master
  • 5,568 Answers
Your description of the problem points to a power supply in the process of failing.
If it was mine, I would leave the set unplugged overnight, remove the back panel of the set, locate the power supply (likely on a separate board related to the incoming AC cable and will have larger components on it), look for an assembly number (often on a printed label), contact the manufacturer's service company and inquire about replacement or repair cost.
When you plug it back in, note whether it behaves normally at first turn-on. If is does, this tends to support the suspicion of a failing power supply since some of the passive components in it have had a chance to recover before weakening again.
Modern supplies are a good bit more efficient than 'linear' supplies of yore but are far more complex and much more dependent on quality of components.
Posted on Jul 28, 2009
After a few months of having it at the JVC recommended shop, they now tell me I need a light engine ($1600). If anyone has a broken screen JVC they want to sell me a bord from, let me know. Thanks.
Posted on Aug 23, 2009
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Lamp or Power issue Panasonic PT56lcz70
I would think that the fact that when you held the power button in for a long time that would give you a hint! If the power button is making a poor contact there will be a small surge of power and some parts of the internal circuits will respond(indicator lights, for example). Try REPLACING THE ON/OFF BUTTON.
Jan 22, 2013 | Panasonic PT-56LCZ70 56" HDTV
Red standby light is blinking 8 times on my sony bravia tv
I simply followed these steps with a surge protector
press the power button and hold up
Then hold up with the power button
then let go of up
and let go of power
worked with my kdl-55ex720
Jul 16, 2011 | Sony 55 KDL55EX720 3D LCD TV
I get a 'the ink absorber is almost full' message. how do i fix it. thx in advance
1. power OFF the printer, covers closed.
2. Hold down Resume button, press and hold Power button; Green lamp will light.
3. Still holding down Power release Resume.
4. Press Resume twice, release both Power & Resume and wait until lamp stops blinking.
5. When light is steady, press Resume four times; the indicator should be green.
6. Press Resume once.
7. Press Power to reset.
Jul 02, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv picture is going out and standby/timer light blinks
Hi Kevin!
The issue may be related to the projection lamp in the TV and replacement may be required. However, before replacing the projection lamp in the TV, you may perform the troubleshooting steps mentioned below.
Please disconnect all the cables from the TV including the power cable then reconnect them after two minutes. Please make sure that the the power cable from the TV is directly connected to a functional wall outlet. Next, you may try connecting any other video source such as cable box, DVD player, Blu-Ray player, Playstation, etc. If the issue persists then try resetting the TV to the original factory settings.
Please follow the steps mentioned below to reset the TV to the original factory settings:
(i) Turn the TV ON.
(ii) Press and hold the Reset button on the Remote Control supplied with the TV, then press the Power button on the front panel of the TV.
(iii) Next, release the Power button. The TV will turn itself off, then back ON.
(iv) Release the Reset button.
If the issue persists then you may replace the projection lamp in the TV.
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
(a) Turn ON the TV.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
JVC HD-52G786 52" Rear Projection HDTV Logo
814 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
