Addes water then no agiting not in gear loud noise plastic on plastic griding
SOURCE: loud noise while agitating in wash cycle
I have the same problem, loud plastic squeak/grind when agitating only. I'd like to fix it, but have never taken apart a washing machine.
The advice below sounds good but where do you start with "begin dissassembly from the tub down"....etc. Anyone have a good internet resource with images for disassembling this machine?
Thanks.
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
SOURCE: kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
