SOURCE: dripping water inside fridge. Can't find drain hose
at the rear of the fridge unit there is a hole, normally at the bottom of a shallow "v" shape. there should be a plastic insert in it to clear any blockages, just wiggle it a bit. failing that a pipe cleaner will do the same.
SOURCE: Whirlpool drain clog
yes it is most likely the drain that is plugged and or frozen up. to repair this you will need to remove the rear access cover inside the freezer compartment clear all the ice from the drain pan and flush hot water thru the drain hole located in the drain pan. this is a fairly easy repair you can do youself. the hardest part will be removing and reinstalling the rear cover. good luck peyton.
BTW I use a turkey baster or large syringe filled with hot water to flush the drain line with.
SOURCE: maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
