Question about Electronics - Others
2 x Jamo Speakers D265 150w long term - 250w short term
I have 2 x Jamo Speakers model D265 which have a range of 150w long term - 250w short term. Could you please advise, could i use these for a disco service coupled to a Torque MA2006 200w amplifier and run for upto 5/6 hours without any problem.
3 Suggested Answers
SOURCE: speakers for pioneer vsx 1018
peoples so whats the best solution?.. if im going trough the same problem...ima going to need a new amp?i unpluged the wire and left it like that see what hapends from their.. :(
Posted on Sep 23, 2011
  • 343 Answers
SOURCE: 250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
Posted on Feb 16, 2012
Replacement remote for Jamo 360 soundbar
Amazon.com: Replacement Remote Control for JAMO TORSTEN 360 ...
https://www.amazon.com/Replacement-Remote-Control-JAMO.../dp/B01E67NI6U
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. *This is NOT an original JAMO remote ...
Replacement Remote Control for JAMO TORSTEN 360 ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls US$38.81 - ‎In stock
This is a custom built replacement remote made by Redi Remote for the JAMO remote control number TORSTEN 360. This is NOT an original JAMO remote ...
jamo replacement remote ' AVForums
https://www.avforums.com > ... > Home Cinema Speakers Oct 5, 2014 - Hello, I have jamo p102 speakers. Unfortunately the remote is broken which means I can't control the speakers at all now. It can't be fixed. Is it... Replacement remote for Jamo 360 soundbar Google Search
Feb 01, 2017 | Jamo Audio Players & Recorders
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
Feb 14, 2012 | Concept Car Audio & Video
With my jamo speakers what should my settings be with my 1. Center delay 2 Surround delay 3. Dynamic range Also what should the db be set at for each of the front, rear and center speakers. ...
Those settings would be through your electronics that drives the speakers, usually using test tones and either special microphones or your own ears. Look at the manuals.
Aug 21, 2011 | Jamo A 310PDD.1 System
Power led on but no output
Try to trace the fault systematically from one end of the system to another, starting with something that you know is working
  1. Start by checking your sound source (cd player or whatever) is working by connecting it to another amplifier or computer.
  2. Check the connecting cable is working from the sound source to the amp and is not shorted out.
  3. Make sure your loud speakers actually work (briefly shorting a 1.5 volt AAA battery across the speaker terminals should produce a crackling sound without doing any damage)
  4. Check loudspeaker cables are properly connected to output connectors and are making a good contact.
  5. Try connecting something like your computer speakers (or use the microphone in jack on the computer itself) to the line output socket of the Jamo. If you can get some sound this way it would suggest that the internal output overload protection fuse may have blown. You will need to open the case to access this. NOTE if your JAMO is still in warranty take to authorised repairer otherwise you may invalidate your warranty.
Feb 25, 2011 | Jamo MPA201 2-Channel Amplifier
Would this speaker work in the jamo gf-25 ?? and if not does any one know what will ?
hi,
it will not be a perfect mach. u have to purchase a speaker with long term power handling capacity of 150W and 4 ohms impedance.
ok
Jan 06, 2011 | Jamo 8.5CS Main / Stereo Speaker
Speakers for pioneer vsx 1018
I think you're making this way more complex than it is.
This unit should have no trouble with any reputable speaker. Don't read too much into short term impedance readings as long as you run only one speaker per channel. Every speaker has a dip somewhere in its frequency range and the Pioneer will probably protect itself and the speaker should impedance or current get too out of whack. This is a high end unit and has plenty of clean power to feed any speakers out there.
I'd buy it if I didn't already have a 6-year old predecessor (VSX-T36TX) that I paid twice as much for and has only 5 amplified channels, less features and lower power output. ;-(
Good luck and happy listening!
Mar 28, 2009 | Pioneer VSX-1015TXK Receiver
Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Mar 15, 2009 | Jamo SW400E Speaker
Jamo i330 i-pod dock has one channel out
I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THERES NO WAY I CAN FIND OUT PASSWORD. IT IS A KLH SURROUND SOUND SYSTEM DVZ-2500 MODEL # IS 0044224000657.I WOULD ALSO LIKE 2 NO IF AND WHERE I CAN GET A MANUEL....
Mar 04, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Electronics - Others Logo
105 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
