..it won't go forward or backwards??.. what..??...HOW are you going to cut grass??.. cutting in one spot doesn't help much huh..??... Is this a riding mower?.. 0-radius turn?...
Seriously.. since we do not know what type of mower you have.. here goes: Take it to a qualified professional.
1. The drive chain is broken or come off the sprockets.
2. Your drive has failed.
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
SOURCE: Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
SOURCE: Mower will shift into forward and reverse gears
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
