Question about Miele W404 Washer
Can you replace the door seal on the miele w404 washer as it is mouldy and we have been unable to clean it?
  • 132 Answers
YES IT IS EASY TO REPLACE:
YOU HAVE 2 RING OF TIGHT:
1-BETWEEN THE OUTER CASE AND the door seal
2- BETWEEN THE SUD CONTAINER
AND the door seal
USING SMALL PLAYER AND SUITABLE WRENSH ,SCREWDRIVER
THANKS
Posted on Jul 28, 2009
Miele W404 not heating
sounds like you need to replace the heating element. Not too difficult as in most washers it is basically a huge version of a kettle heating element. Look up on line how to replace this for your model of washer.
Feb 24, 2013 | Dishwashers
Miele w404 dead not lighting
firstly check the power. secondly check the door is closed properly and push hard on it as the door lock needs to be engaged for the light circuit to then light up. it could be a faulty door lock
May 14, 2010 | Miele W404 Washer
I have a front loader washing machine. The rubber inside is going mouldy. I have tried to clean same without success - any suggestions!
Unfortunately, once the door seal goes mouldy it is impossible to get clean. Only option is to replace seal. Once seal is replaced, you need to wipe it dry after each wash and leave door ajar to prevent reoccurence of mould.
Mar 09, 2010 | Maytag Washing Machines
Leaking door seal on a W404 Plus
Make sure the door is closing properly,and check the door is not loose, and that there is no build up of lime scale on the door glas.
If all o/k, then only solution is to replace the door seal.
Jan 18, 2010 | Miele Washing Machines
Mouldy door seal on hotpoint ultima 14 months old
hi, has the seal been replaced?if not use an old tooth brush and clean it with tooth paste it will clean off the mould, if the seal has been replaced check around the rim for a drain holle it may have been fitted wrong, some dont have drain holes hope this helps
Feb 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Mouldy rubber seal
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Regarding the mould; keep your door open after yur washing is done, (means dont shut it tight) it will help to dry the insides & prevent moulding. Only see your cat is not inside before starting a new wash.
And pl rate me if helped.................
Jan 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Replacing door seal
Try washing the seal with jiff and a scouring pad in warm water.Depends on how well it is ground in.
You may have to replace with new seal.
slimjim1
Nov 25, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Miele W404 Washer Logo
558 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
